Results 1 to 9 of 9
    May 24 2016
    Spokane, WA
    2013 A5 PPI - Joining the Club
    Hey guys,
    I've been searching for an A5 for awhile now and may have finally found. It's currently at a dealer in Bellevue. Any recommendations on a shop for a PPI? Audi Bellevue costs $420 while Redmond European is only $200. Any other places I should be checking out? I find Audi Bellevue to be quite expensive for just a PPI unless they do an incredible job. Thoughts?
    Apr 05 2016
    Portland, OR
    First thing I would do is contact AoA and get all the information from them about the car. (Give them the VIN and they can provide you the rest)
    Notable things: Check to see what work they have on record for it. (Any issues, services, etc)
    Check to see if the previous owner already purchased Audi Care or extended warranty and ask about transfer information. (Even if they did the dealer will often bundle it in and charge you for it )
    Ask for a copy of the window sticker just to have it for your records and to get a better run down of the options.
    As for PPI, take it to a good indy shop that works exclusively on VAG cars.
    Geoff
    Veteran Member Four Rings CupcakeS5's Avatar
    Jul 18 2009
    Your mom
    Achtuning would also be a great place to call for a PPI
    I know violence isn't the answer. I got it wrong on purpose.
    "Then you get ecodes, and it's like beer tastes better, tits are perkier, and things are just right in the world." -i1overice
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by whiped View Post
    lemme add:
    make sure you have 2 smart keys and the plastic emergency key
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    May 24 2016
    Spokane, WA
    Thank you for directing me on things with the car. I appreciated the help. I got it inspected and I purchased it!
    Apr 05 2016
    Portland, OR
    Congrats!
    Pics?
    Geoff
    May 24 2016
    Spokane, WA
    Thank you!
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    Looks flawless! I like the wheels too!
    May 24 2016
    Spokane, WA
    Thank you! Already gotta take it for the 35k maintenance and get the vacuum hose looked at, there seems to be a leak (CEL on). Just my luck :/
