Results 1 to 7 of 7
    Senior Member Three Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Catch Can causing valve cover gasket leak
    Hey all,
    I recently installed a CTS Turbo catch can in my B7 A4. The PCV system was functioning normally, but I'm getting ready to flash a JHM stage 1 tune and wanted to replace all worn/failure-prone parts beforehand. I hooked up the can as per the instructions and everything seemed to be fine, but after about 2 days of driving, I noticed some residue from a small oil leak. It looked to me like it was coming from the valve cover gasket. I removed the catch can and went back to stock, and was able to take it into the dealership since I had a bit of warranty time left. They confirmed that it was in fact the valve cover gasket that was the source of the leak and replaced it under warranty.
    Now that the gasket has been replaced, I'm hesitant to reinstall the catch can if I'm going to have another issue with excessive crankcase pressure. I did notice that with the catch can installed and the car running at idle, if I loosened the oil filler cap it would bounce around. I was under the impression that it should be under light vacuum.
    I realize that PCV questions have been covered on here ad nauseam, but I haven't come across anything specifically related to blowing out a valve cover gasket. It seems like a good amount of people are running catch cans without any issues, so I wanted to get some feedback before deciding how to approach this situation.
    Thanks in advance,
    Will
    I didn't take any photos of the catch can installed, but it was hooked up in the exact same way as in these instructions from CTS Turbo: http://www.ctsturbo.com/cart/CTS%20C...tions%20RE.pdf
    Established Member Two Rings Audi4turbo's Avatar
    Jun 19 2007
    2007 Audi RS4, 2017 Chevrolet Colorado ZR2
    Lutz, FL
    I also had this same problem in my old car, and need to part ways with my current stock PCV. I'd also like to see what others say, but I am going to try a vented CC to bleed off the excess pressure.
    2006 A4 S-LINE
    Qauttro Manual
    Performance: APR 91/93/100 Programs; Carbonio CAI; Stassis Exhaust
    Exterior: Caractere Spoiler; RS4 Grill
    Audio: 7" Alpine in dash NAV; JL Audio 300/4 & 500/1 Amps; MB Quart QSD 216
    Other: Hardwired Passport 9500 with Escort Live
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    How many miles on the car currently?
    Sent from my C5306 using Tapatalk
    Ivan
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    64,xxx
    May 09 2012
    Virginia
    Was there anything in the catch can? Anything that impedes flow through the PCV system could increase crank case pressure and result in a VC leak.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by jbain2 View Post
    I changed my crankcase breather tubes yesterday, the one that goes to the bottom was 3/4 full of dry carbon deposits. Check that also.
    My respray thread
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    The catch can seemed to be working, I emptied the same nasty looking liquid that I've seen in a few other CC posts
    I'll have to check the crankcase breather tubes as well. I'm wondering if running the can without the dipstick installed would help relieve some of the pressure.
