Results 1 to 7 of 7
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    FS: ECS 15mm Spacers with ball seat bolts - No Longer Available
    Ill upload a picture when I get a chance. I have a set (front and rear) spacers that were only on my car for about a month. Was just experimenting with the look but it just wasn't for me. They come with the OEM type ball seat bolts. Technically these can be used on any newer Audi because they all have the same bolt pattern.
    List Date: 5/25/2016
    For more info, click here to view the original listing: FS: ECS 15mm Spacers with ball seat bolts
    This item is no longer available.
    Feb 11 2016
    earth
    I'm really interested. Do you have a picture of them on your car?
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by fatboydelights View Post
    Unfortunately I don't. I really didn't have them on long enough but they were about as flush as I would go. Anything bigger and they would poke a bit and you would most likely hit fender if you were lowered.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Mar 20 2004
    Lawrenceville, NJ
    These are still available.
    20 BMW R1250RS
    Mar 20 2004
    Lawrenceville, NJ
    Bump
    20 BMW R1250RS
    Jun 07 2016
    Europe
    Quote Originally Posted by HyperM3 View Post
    Bump
    Does the 15mm rub when lowered, or why are you selling it?
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by Logtec View Post
    No, they wont rub as long as you only use the VAG to lower the car. If you use the additional links or module then you will rub, but youll probably rub with any spacer at that point. Im selling because Im parting out my car.
    20 BMW R1250RS
