Results 1 to 4 of 4
    May 24 2016
    Syracuse, NY
    Please Help! Car Won't Start!
    My 2007 A6 3.2 Quattro will crank but won't start, it seems like it's about to start but then turns off, then if I try again it just keeps cranking. Automatic cranking doesn't seem to work, or it works intermittently. It's giving me a lot of error messages/warning lights on the dash too (like everything--parking brake, airbag, TMPS, EPC, sometimes saying there is a parking brake fault, and it seems like if I let it crank for long enough it gives an oil pressure warning, although I figured that's from turning the engine over for an extended period of time). This is all after not driving the car for a few days and then replacing the third brake light in the back window today. My friends who were there said the first time I turned it over the fuel pump made a funny noise, then stopped. Anyone have a similar problem or know what's going on? I will probably have to call a tow truck....
    Established Member Two Rings kocyk123's Avatar
    Nov 02 2015
    2001 Audi A8L
    Harwood Heights IL
    Had same symptoms with mine 2007 4.2. High pressure fuel pump was bad. I also had TMPS and EPC lights on along with some random Check Engine codes. Have your Fuel pumps inspected.
    Current rides:
    1. 2013 Hyundai Azera Tech 50k miles
    2. 2001 A8L 4.2 Quattro 211k miles
    Sold:
    1. 2007 A6 4.2 FSI Quattro 77k miles
    2. 2007 Acura TL Nav at 86k miles
    3. 1996 A6 Quattro at 155k miles
    Established Member Two Rings Euro_head's Avatar
    Mar 11 2014
    96 A4 B5(sold), 98 A4 B5(sold), 03 A4 B6(sold), 01 A4 B5(rip)
    Reading, PA
    I had a problem like that a couple months ago where at times my car would Crank but it wouldn't start and if if did it would shudder back off . For me it turned out to be a super closed fuel filter but your probably is most likely gas related
    Veteran Member Four Rings jbrentd's Avatar
    Oct 31 2005
    '13 allroad, '91 Coupe Quattro, '64 Corvette, '93 Corvette, '21 Bronco
    Tulsa, OK
    I also had the HPFP replaced on mine. It would start, but run really rough and die sometimes. Intrument panel would light up like a Christmas tree. Started off intermittent, but then became more and more frequent. My extended warranty paid for itself on the first trip to the dealer.
    1991 Coupe Quattro - Project Car
    2013 allroad - My DD
    2011 A3 S-Line - Son's DD
    SOLD - 2007 A6 4.2L // 2001 Pelican A4 Avant // 1996 A4
