Results 1 to 27 of 27
    Feb 13 2004
    Silicon Valley, CA
    Car seat recommendations for B8 Avant
    Ok, first (and only) baby is on its way and expected at the end of August, so any recommendations on car seats?
    I don't think I want one of those type that are good from 0 -5-6 years. I would rather get what I need now.
    So, any input on what works really good in an Avant?
    TIA
    Kevin - Moderator, Audizine
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by Stubek View Post
    TIA
    Congrats on the little one on the way! We put our first two in this Chicco. Granted, this seat spent much of the time in my wife's Outback, but it also fits well in the back of my avant and the car seat also mates up to a stroller.
    http://m.target.com/p/chicco-keyfit-...w&gclsrc=aw.ds
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Aug 06 2012
    Parker, CO
    We used these for both of our kids right after they were born until just after their first birthdays.
    http://www.toysrus.com/buy/travel-sy...00070-80055846
    Then, put them in seats similar to this one
    http://www.amazon.com/Evenflo-Platin...V7K4ESK28CP55Z
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    This is what we got for our daughter who was born in December
    http://www.gracobaby.com/products/pa...x-cascade.aspx
    Much like all the others on the market it has a base that can be installed in multiple vehicles so swapping between my wife's car or our parents is a breeze and it also clicks right into the stroller which is great for getting in and out of the car if we are doing things
    And don't forget the seat protector
    http://t.toysrus.com/product/index.j...:17200806:TRUS
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Good options. We upgraded to the gracco kids booster seats as well.
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    I bought this one for my first granddaughter actually bought 3 for the kids cars and my Avant :).
    https://www.diapers.com/p/recaro-per...221?sku=RC-078
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    first of all, congrats on the baby! life is going to change a lot, and mostly for the better! parenthood is awesome!
    +1 on the chicco keyfit for newborns. i like the snap and go feature, which i think some other companies offer.
    if you are staying with one kid then putting it in the middle works, but there is no latch in the middle, so you need to hook up with the seatbelt.
    I have a recaro performance ride for my 3yo and it works pretty well. rear facing on the side needed a bit of muscle and a pool noodle to have it secured enough to my liking.
    With the recaro behind the passenger and the chicco in the middle, as a 6' driver, I had to move my seat forward and less recline than I would like, but not terrible enough to make long (3hrs) trips uncomfortable.
    now with the recaro forward facing, the chicco in the center is a tight fit...need to jam it in as the recaro is a bit wide to go side by side with the chicco...there are better options for a two seat setup (in hindsight, i would go with a narrow convertible like the clek fllo), but i didnt want to get rid of the recaro and buy a new seat given that the majority of the time we dont have the avant fully loaded (usually take the wife's suv)
    also, I highly recommend seat guards - i have the brica seat guardian
    feel free to pm me if you have specific questions...i did a ton of research on the topic.
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    TIA
    Why not get what you need now, and have it last?
    We have, and highly recommend, a Britax Click Tight Boulevard. We have been using it since our son was a newborn; it has rear-facing capabilities to 45 lbs; it lasts until 65 lbs when forward facing.
    The biggest advantage of the Click Tights is the ease of installation; it can be moved from one car to another AND installed correctly in less than two minutes. A fringe benefit of the Click-Tight mechanism is the ability to unlock it when not in use, which takes the compression pressure off of your back seat.
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Quote Originally Posted by kdaffy View Post
    Man you just settled my anxiety with this post. I too am expecting a kind (Sept). We have the Cicco keyfit seat because my wife researched the hell out of it and claims it is the safest one on the market. Only using reviews for the seat guard on Amazon, I bought two of the Brica Seat Gardians as well. I was nervous about the seat guard, but this eases me off the ledge. Thank you for that.
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Jun 14 2009
    GA
    When our daughter was an infant, we used the Britax Chaperone. This was fantastic for us since we could install bases in each of our cars that the carrier would snap into. Putting her in and out was a breeze. Once she grew out of that, we went to a Britax Boulevard. And now, she's in a Britax Parkway SGL.
    I've used these in both a B7 and B8. They all fit very snugly with the LATCH system. Overall, we have been very happy with them.
    That being said, if we had to do it all today -- we'd just go with the Britax Boulevard ClickTight ARB. The ability to snap in and out of bases cannot be emphasized enough. It really does make things much easier. That's the one thing I missed the most when we went from the Chaperone to the (original) Boulevard.
    2018 IA6 3.0T Sport | Glacier White Metallic | Black Optics | Carbon Atlas | XPEL PPF | Gyeon Quartz
    Gone, but not forgotten:
    2014 A6 P+ Quattro, Quartz Grey Metallic
    2010 A4 P- 2.0T Quattro 6MT, Quartz Grey Metallic
    2007 A4 S line 2.0T 6MT, Phantom Black Pearl
    Established Member Two Rings moe.ron's Avatar
    Apr 26 2016
    ladies love my Toyota Sienna
    Harrisburg, PA
    I have used 2 different Gracco SnugRide 35s for my three kids and have no complaints. The 35 is sized for children up to 35 lbs so you will get several years of use out of it without using a seat that is sized for a 5 year old. It can go can go forward or back and can attached to Gracco strollers. They fit well in the back seat of the Avant (B8). My understanding is that car seat manufacturers are regional, so in order to buy a Gracco in CA you would have to use the internet as no brick and mortar stores will carry them.
    2011 A4 Avant
    Mods: some stuff and things and a quattro license plate frame because the it's the little things that count
    Apr 17 2014
    MA
    Quote Originally Posted by poweredbyaudi7 View Post
    no problem. happy to help a fellow 'ziner!
    Oct 01 2014
    Pittsburgh/PA/Penn hills
    Got this for the new baby recently. Your wife would love it! Car seat and stroller
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    I got this Uppababy because my wife wanted to have a base in each car and she wanted that seat since it went with the stroller she wanted. It's fine. Apparently it got good safety reviews, but it's a bit heavy and large, but I think all the rear facing seats are big. Once the kid got a little older, I moved over to this recaro. It looks cool, but it's pretty damn big.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Mar 28 2009
    Minneapolis, MN
    We used a Chicco KeyFit 30 for both kids when born (and my 8mo son is still in it), and then we switched to the Chicco NextFit CX. It's a big seat, but install is quick and easy once you get the hang of it, and feels very sturdy when installed. Lots of reclining options for the best fit, and plenty of padding for comfortable kids. Our 2 1/2yo daughter has been in it for as long 3-4 hour trips (with stops) with no complaints. I'll be getting 3 more NextFits for our son when he's ready for a bigger seat.
    I'm also using the Brica Seat Guardian in both cars, and have a couple front seatback protectors that will go into use when the kids are front-facing.
    Established Member Two Rings X Y Z's Avatar
    Mar 20 2013
    SM610, AE86, FJ60
    Portland, Oregon
    Another Chicco Keyfit30 vote, fits great in the Avant. My son is now four and we have been using a Recaro Proride for the past few years, it is a tight fit but I am not willing to give up the wagon lol
    Feb 13 2004
    Silicon Valley, CA
    Thanks everyone. Going shopping this week to look at a couple of these in person
    Senior Member Three Rings redge2.7t's Avatar
    Jun 24 2010
    VW Atlas
    Folsom
    Congrats!! My wife and I had our first on May 22nd, 3 weeks early, but besides that happy and healthy. We went with a Graco Snugride 35 Click Connect and I couldn't be happier with our choice. Here it is when I first installed it.
    After realizing that just a towel wasn't going to be enough to protect my seat I bought this seat protector and it works and looks great. I don't have a pic of it in though. Here is the link for it https://www.amazon.com/Child-Car-Sea.../dp/B010UDHXHE
    One thing that makes this setup super easy is we bought separate bases for my wife and my cars. It makes everything so much easier.
    Congrats again and enjoy the new edition to your family!
    Just for fun here's a pic of our little girl at her 2 week mark.
    Current- Vesuvius Grey C8 S6 Prestige- APR Carbon Intake, APR Tune, ECS Spacers
    Former- Quartz Grey B8 A4 Avant_Prestige_S-line_(1 of 7) REVO Tune, aFe, ECS TIP, RS4 Grill
    Former- Stage 3- C5 A6_too many mods to list.
    Aug 06 2012
    Parker, CO
    One more thing - read the owners manual for best seat location placement
    Established Member Two Rings billybob_lee's Avatar
    Apr 19 2013
    2006 Lexus SC430, 2014 Toyota Highlander Hybrid Limited
    Huntington Beach, CA
    Like many posters here, I also used a Chicco Keyfit30 for both our kids, and upgraded them to Recaros as they got older. In the Child Car Seat thread, I posted a photo of our current set up: http://www.audizine.com/forum/showth...1#post11433292
    I agree with other posters in that the Brica Seat Guardian is the best seat protector to buy. I used a Prince Lionheart before, but the seat-back portion of that protector didn't go high enough. Recently, my youngest son vomited in the car, and the seat protector not only caught some of the run-off, but also shielded the seat back from staining. If I had the Prince Lionheart in at the time, it would not have protected my seats as well.
    2013 allroad, Premium Plus, Glacier White Metalic w/full paint finish - Gone
    2014 allroad, Premium Plus, Phantom Black Pearl
    MMI Plus w/Nav | Sport Interior | Advanced Key | B&O | VMR V706 w/Michelin Pilot Sport A/S 3 (255/40-19)
    OEM RS5 Pedals, UV Privacy Sunshades, WeatherTech, Canvasback, OEM Warning Triangle, OEM A8 Leather OM Wallet, VAG-Com
    Feb 13 2004
    Silicon Valley, CA
    Question for people with the Chicco Keyfit 30, can you put it in the middle seat of the back seat?
    Mar 28 2009
    Minneapolis, MN
    Yes
    Senior Member Two Rings ranchos's Avatar
    May 05 2014
    United States
    +2 yes. However in this install you need to use the seatbelt and not the LATCH points. What's nice about a center install is you can keep both front seats in a comfortable driving position.
    Aug 06 2012
    Parker, CO
    Reminder --- please read the owners manual for the car to find the best position for your baby's car seat
    Established Member Two Rings dbv2's Avatar
    Mar 06 2016
    To
    Graco Click Connect 35.. The whole stroller system with car seat is by far the best system out there. $600 ish CAD for ours. Baby doesn't know a thing when shes being put in the car from the stroller and vice versa. We went with the jogger stroller with inflatable rubber wheels rather than the dinky plastic solid wheels.
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by ranchos View Post
    I was able to use the LATCH points in the center position with our KeyFit30 base.
    May 05 2014
    United States
    DO NOT DO THIS! The LATCH system is only specced for the outboard seats. You're compromising safety by spreading out the anchors to either side. Use the seatbelt for middle configuration!!!
