Results 1 to 2 of 2
    May 12 2016
    Tulsa, OK
    Evap Emission Leak
    I dont know exactly what the code is at the moment will pull tomorrow at work but let me start the story out.
    My check engine light goes on and i pull codes X2 of the exact same codes. I fix the one (Crack in the o-ring on the gas cap).
    The second.. well I have no idea. I need some help. Like i said will update when i get the exact code.
    2008 B7 A4
    2.0 T
    CVT
    FWD
    Feb 08 2012
    Dallas, GA
    You're saying you get 2 of the same code at the same time? One is usually a freezeframe and contains more diag data. Fix what you think is the problem, clear them, drive to readiness (usually 50-90 miles when it's an EVAP issue), and see if you fixed it.
