Results 1 to 10 of 10
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Removal of Tape residue
    Cross posted in the main forum as well;
    Earlier this year I had to tape off my sunroof due to the dreaded rain tray issue on the Avant. Fast forward to sunny days and no rain - peel off the tape and now I have a bunch of residue left. Got some of it off with WD40 and Goo Gone but the rest is a stubborn b****! Any suggestions?
    Heat gun?
    Edit: I was recommended rubbing alcohol and finish off with a wax/sealant.
    Thanks,
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Veteran Member Three Rings MyXbfS4's Avatar
    Jan 18 2015
    2000 B5 S4 Light Silver w/ Onyx (no sunroof), 2009 A4 Black
    Los Angeles, California
    Quote Originally Posted by Copen-cisco View Post
    Heat gun?
    Thanks,
    also depending on the surface Magic Erasers work wonders on removing sticky residue. may not have applied in this situation but may in the future
    2002 Laser Red B5 S4 Sedan
    2011 Ibis White B8S5 4.2V8 Coupe
    2000 Silver B5S4 6mt Sedan(no sunroof)- SOLD
    2001.5 Silver B5S4 6mt Sedan stg3- RIP
    2000 Santorin B5S4 Tip Sedan- RIP
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Use denatured alcohol and wipe light with a rag then cover with wax
    Active Member Two Rings McWicked's Avatar
    May 23 2016
    '71 Datsun 510
    NorCal
    It depends on the type of adhesive used on the tape. IPA (rubbing alcohol) will typically clean the actual adhesive but won't remove the rubber/gum binding agents. Nor will it touch any silicone release additives. In my experience a product made by 3M, that's conveniently called 3M General Purpose Adhesive Cleaner, is what you're looking for.
    Sep 06 2013
    Dublin, CA
    Quote Originally Posted by MybfS4 View Post
    Quote Originally Posted by Peter.dupuis View Post
    Quote Originally Posted by McWicked View Post
    Thanks all. Adding a picture in few moments. Maybe that will help to determine what product to use.
    Edit. Pic attached.
    Kristian
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    Wax & Grease remover from a auto paint supply place.
    May 23 2016
    '71 Datsun 510
    NorCal
    First off, don't use duct tape.
    Anyway like I said, 3M General Purpose Adhesive Cleaner will do the trick. As a side note, for short term taping jobs gaffer's tape does about 90% of what duct tape does without leaving all that crap behind. It's a bit spendy, but you'll save on the elbow grease come removal time.
    Sep 06 2013
    Dublin, CA
    Great info! It was a last minute thing.. pouring down and leaking into seats etc. I will pick up the 3M cleaner.
    Kristian
    Deactivated Four Rings
    Jun 23 2011
    I have always used a tin of Mothers Carnuba cleaner wax. It takes off the glue and residue and does not hurt the paint or anything. Smells good too.
    Sep 06 2013
    Dublin, CA
    Quote Originally Posted by Sales@EPL View Post
    Thanks Chris! I will let you all know how it turns out over the weekend. JUST picked up the 3M Cleaner and have 91% Alcohol at home so I should be successful.
    Kristian
