Hello all, here are my issues.
2002 Allroad 2.7t 6MT Stage 1
Symptoms:
1. A/C started getting really warm while at idle. Ice cold when driving.
2. Started noticing the temp creeping toward 3/4 hot when idling for extended periods.
3. Haven't seen either electric cooling fan come on by itself (in front of radiator and behind on passenger side). My understanding is that the passenger side electric fan should always be on whenever the A/C is on (without ECON).
4. Hearing a lot of periodic hissing when the A/C cuts in and out at idle. About every minute or so (normal?). The hissing coincides with the a/c getting warmer.
What I tried so far:
Had A/C charged. They put in about 2 ounces. I didn't notice any difference.
Took to the local Audi indy shop. They said bad fan control unit, which coincided with what I had read in online forums. They bench-tested the electric fans and both worked with direct power. They wanted $600 to repair, so I thought I would take a shot at it. Ordered a replacement from URO Parts for $85 (mistake?).
Installation wasn't terrible. Managed to get both nuts back on and the wires back in the factory routing. However, the electric fans still don't come on. Even with A/C full cold, no econ switch, Oil temp around 225, and coolant temp 3/4 scale hot. Turning the heater on brought the temp back down. Oddly enough, even with the heater full hot, I was still hearing what sounded like the a/c compressor kick on and off, with the associated hissing sound. I also noticed my climate control tries to automatically control the fan speed when I adjust the temp, even though the AUTO mode in not selected. Not sure if this is normal for this car, or if my climate control module is going bad.
I changed the fan control switch (blue) and coolant temp sensor (green). No change.
I pulled the fan connections next to the washer reservoir and applied 12v to the two different two-pin connectors for the fans. The reddish-brown one for the fan in front of the radiator, and the black one for the passenger side fan. The fans came on. I had to give the fan in front of the radiator a gentle nudge, but it came on (maybe because I was using a pretty small jumper wire made from speaker wire?).
I used a multimeter and checked the other side of the connection coming from the fan control module, and only have around 9.8 volts d/c or so to each fan. I don't know if this is normal, or if I should have a full 12 volts. I read something about pulsing/modulated power yadda yadda yadda from the FCM, so I'm not sure what exactly I should read coming out of the FCM. I was expecting 12 volts though.
So, did i get a bad replacement from URO Parts, or is there something else I'm missing? Also, I assumed the fans not working had something to do with the A/C getting warm at idle, but could I be dealing with two separate problems?
I could use some additional insight. The only thing I can think to do is try a different FCM. I hate to drop the $215 for a new factory one, but I probably should have. Then I wouldn't be second-guessing the status of the replacement.
I await your expert tutelage, oh great forum masters!
