Results 1 to 7 of 7
Thread: Any ideas
    May 24 2016
    Glasgow
    Any ideas
    Hi guys I have a 2007 a4 2.0 sline 170 and have had an issue with no power below 2000rpm after that it seems to be fine but really poor before that. Eg will stall if revs are not up at about 2000 rpm when pulling away. i have into different garages but to no success. Have replaced egr as these seamed to be the common factor with this fault. Any any ideas
    Aug 04 2015
    Kansas City
    Quote Originally Posted by Muzzamc View Post
    Has any garage scanned it with the VAGCOM? Are you taking it to Audi/VW specific garages or general repair shops?
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by KJack View Post
    +1 Sounds like a lot of guessing going on here. For what you've already spent, you might take it to an Audi dealer and know what the problem is right away.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    You have 2 options. take it to an indi shop with only Audi/Vw/Porsche specialist with vag-com. find out what really is happening and fix. or pay $145 diagnostic fee at dealer and find out as well. but to your problem no power can be spark plugs,ignition coils, Turbo going bad. even a bad catalytic converter will make your car with no power.
    Ivan
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    2.0 TDI?
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    It sounds like a vacuum leak to me. Do a smoke test. If you have check engine light then get the codes
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    May 24 2016
    Glasgow
    Yeah sorry it has been to an Audi specialist with vagcom and still no further forward plus has had a smoke test. It gets plenty of boost after 2000rpm and doesn't have a cat or dpf
