    Account Terminated Four Rings
    Jan 15 2016
    '08 A4 2.0 Avant 6MT S-Line Ti
    SoCal 626
    Exclamation Porsche Cayenne 18z calipers (new brembo pads, wear sensors, hardware)
    Selling a complete set of 18z calipers in perfect working order, have like new brembo pads, wear sensors, anti rattle clip, bolts. They still have a portion of the original brake lines attached to the caliper to keep from any dust/debris from entering the brake lines, they'll want to be discarded once you have your new brake lines. Calipers just need to be cleaned up with some degreaser or the sort and they'll look good as new, pink marker on the calipers come off very easily.
    SOLD build your own kit for a faction of the price of this $2000 kit that uses the same calipers https://www.ecstuning.com/Audi-B7_A4...tage_4/ES1896/
    These are ready to bolt on with the right brake lines, rotors and mounting hardware like the ones from jhm, ecs or http://audibbkparts.bigcartel.com/pr...dware-for-audi
    Calipers work for the following cars but do your research on exactly what you need to complete the kit here http://www.audizine.com/forum/showth...de-what-rotors (30+ pages but I recommend reading through this thread thoroughly)
    -B5 S4
    -B6/B7 A4/S4
    -C5 A6/Allroad
    -MK5/MK6 VW Golf and Jetta
    Dec 19 2011
    Colorado Springs
    So the question remains...which are the easiest least hassle rotors to use without having to do major modifications?
    Do you think these would clear behind B6 S4 wheels? 18"
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Jan 15 2016
    SoCal 626
    Mercedes ML55 rotors would be the easiest, only mod needed would be to open up the center bore 1mm.
    Not sure about B6 S4 wheels but they cleared my B7 Titanium Package wheels that are 18x8 +43 offset w/ a 10mm spacer.
    Dec 19 2011
    Colorado Springs
    Quote Originally Posted by malathion View Post
    B6 S4 wheels should be 8Jx18 ET45
    Did you need the 10mm spacer to clear them?
    Whats different between these and the 17z?
    Jan 15 2016
    SoCal 626
    I used a 10mm spacer to make the wheels sit flush with the front fender, could have probably got away with a 5mm spacer to just clear the calipers.
    17z are smaller length wise, width wise I believe they are the same.
