Results 1 to 12 of 12
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    Question 034 breather kit issue
    Im having a strange issue with my 034 breather kit. I noticed when replacing my jet suction pump a loud air hiss noise. When i looked, I saw that the silicone hose going from the intake manifold to the billet pcv valve was collapsed at idle. Does anyone know why its collapsing? The pcv valve appears to be working fine. Im gussing its the weak silicone hose that cant take the suction. Can anyone also confirm that the oem hose part# 06B103224C from the early b6 is the one i need to replace the 034 hose with?
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Are you sure the pcv is not stuck closed or plugged? The PVR valve could also be plugged. There should not be that much vacuum on that hose to cause it to collapse. Try removing the oil cap at idle and see if it still collapses. If it does not I would check your PRV.
    If the breather system is working fine then like you said the hose is weak and collapsing. And that is the right part# for early B6 OEM hose, PCV system changed in 03.
    Aug 22 2004
    Idle is at -19. Removing the oil cap makes no change to the hose, still collapses. The oil cap also bounces around as it should and does not get sucked down. Seems the issue is a weak hose.
    USP CLUB MEMBER #7
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Make sure that your PCV valve isn't stuck closed or only opening part way.
    Aug 22 2004
    When I took out the billet one, I was able to blow through it. I had this cheap plastic pcv valve installed and the hose still collapsed with that one in place. The valve doesn't seem to be my issue. I just ordered an Oem hose as it appears much stronger than the 034 hose. I will update when I get it to see if that fixes my issue.
    USP CLUB MEMBER #7
    Feb 02 2016
    02 A4 1.8t quattro Sport 5 speed, 87 4Runner (rock crawler), 06 4runner, 99 Suzuki Bandit 1200S
    Richmond, VA
    When I installed my 034 kit it came with the wrong hose to go to the PCV so I just used my stocker and fortunately it was the only stock hose in good condition. Maybe that was a good call after all...
    Sep 17 2005
    Fremont, California
    Sorry to hear you're having an issue! The hose should not be collapsing; feel free to email Sam at [email protected] for assistance. I'd recommend checking to make sure that there isn't an issue with the check valve or PRV, and ensuring that the hose isn't tweaked or pinched from installation. Hope that helps!
    Aug 22 2004
    Oem hose fixed the issue. The hose no longer collapses at idle. Also,Thanks to europaparts for the 1 day shipping too.
    USP CLUB MEMBER #7
    Jun 26 2015
    Tampa, FL
    Quote Originally Posted by GTRchop88 View Post
    That doesn't make me excited to install my kit.
    Jan 06 2009
    Zero issues with the reliability of my 034 silicon breather kit. It has been used daily for 3+ years.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Aug 22 2004
    I am using the rest of their kit. Just comparing the 034 PCV hose with the new oem one, The 034 hose is very weak. Idk if its from the oil seeping through the silicone over time that made the hose weak.
    USP CLUB MEMBER #7
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    I have had my 034 hoses for years now also with no collapsing issues, but it does seem like oil is sweating through the hose.
    Please Drive Right
