Results 1 to 2 of 2
    Jul 15 2015
    Rochester NY
    Replace transmission front oil seal 06 B6
    Hi all, is there any special technique required for replacing the oil seal on the manual transmission input shaft? I'm figuring it's just a matter of digging out the old one and pushing the new one in, without removing the shaft. I have the gearbox sitting on my garage floor, and the clutch compartment is fairly oily, looks like it's a transmission leak. I'm replacing the engine rear seal while I have it open for the timing service.
    Feb 18 2014
    Arizona
    There is an o-ring as well as the seal that goes around the shaft, I'd replace both. here is a pdf that shows the recommended procedure - https://www.scribd.com/doc/313627008...ease-Mechanism
    I am doing this myself as well so i'm glad you posted this. I'm wondering if anyone can recommend an equivalent product to use in place of the oem "sealing grease"?
