Results 1 to 2 of 2
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    name that price game
    Looking to sell a car that i will no longer be keeping as i found my b6 s4 chassis.
    im in the north of 10k and less then 15k area
    Silver with black interior
    170k miles on body
    really clean interior
    exterior is pretty clean but both front fenders are for an a4 and the color is slightly off
    cracked windshield
    whats its got
    2.7 twin turbo
    Built bottom end
    integrated engineering rifle drilled rods
    Calico coated bearing w/ rifiling holes
    Total seal piston rings (gapless top rings)
    Engine balanced to 9,000 rpm
    Fx400 clutch
    Aasco 11lb flywheel
    Ssac downpipes
    AWE drive train stabilizer
    Stasis engine mounts
    034 racing density tranny mounts
    Jhm shifter
    Suspension:
    Eibach springs
    Bilstein struts
    H&R rear sway bar
    New rear cross member
    Wheels:
    Adams rotors track rotors (double slot, dimple)
    Hawk performance pads
    Rs4 replica wheels 18"
    nib that will be installed
    brand new k24's with inlets and hardware
    bosch ev14 1000cc injectors
    tuned on 91 and e85
    scg1 boost controller and afr gauge with boost cut for afr and over boost
    walbro 450 intank
    only photo i have on my phone right now - shows the slight color difference in the front fenders
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Lot of work done, good luck man! Hopefully she finds a good home
