Results 1 to 40 of 54
    Sep 17 2005
    Fremont, California
    New: X34 MQB Carbon Fiber Cold Air Intake System for 8V Audi A3/S3 + Raffle!
    The X34 Carbon Fiber Audi MQB Cold Air Intake System for 8V/8S Audi A3/S3/TT/TTS & MkVII Volkswagen Golf/GTI/R equipped with 1.8T/2.0T Gen 3 engines has arrived! This true cold air intake yields horsepower and torque gains throughout the powerband, with peak gains of up to 15 crank horsepower and 12 ft-lbs of torque with the factory turbocharger.
    034Motorsport’s engineers thoroughly evaluated the factory airbox design to create a performance replacement that reduces pressure drop in the intake tract, while offering OEM+ fit and finish. The result is this complete one-piece MQB Carbon Fiber Air Intake Upgrade, which offers 100% bolt-on installation without the need for any additional pieces.
    Peak Wheel Horsepower & Torque on Stock 2016 Audi S3:
    • Stock Intake: 232 Wheel Horsepower / 241 Wheel Foot-Pounds of Torque
    • 034 Carbon Fiber Intake: 240 Wheel Horsepower / 248 Wheel Foot-Pounds of Torque
    • See Dyno Chart
    Features:
    • Developed In-House by 034Motorsport's Engineering Team
    • One-Piece Design with High-Quality Carbon Fiber Construction
    • OEM+ Fit & Finish Retains Factory Lower Airbox & Inlet Duct
    • Fully-Enclosed Design with Large Diameter 4" Inlet Pleated Cotton Air Filter
    • Large-Diameter CFD-Optimized Air Intake Tube
    • Dyno-Proven Horsepower & Torque Gains
    • Improved Engine & Induction Sounds
    • Increased Throttle Response
    • Improved Airflow from Factory Airbox & Intake Tube
    • Compatable with SAI Equipped & Non-SAI Equipped Vehicles - No Additional Parts Required!
    • Installs Easily in Minutes!
    What's Included:
    • 034Motorsport Carbon Fiber MQB Air Intake System
    • 034Motorsport Double-Layer Pleated Cotton Air Filter
    • Integrated SAI Adapter Fitting
    • Installation Hardware
    Compatible Vehicles:
    • 2015 - Present Audi A3/S3 (8V - MQB) - 1.8T & 2.0T
    • 2016 - Present Audi TT/TTS (MkIII - MQB) - 2.0T
    • 2015 - Present Volkswagen Golf/GTI/ R (MkVII - MQB) - 1.8T & 2.0T
    • Please Note: This comprehensive air intake system is designed to install on vehicles with or without factory secondary air injection (SAI) systems. No additional parts are needed!
    Product Information Sheet:
    Installation Instructions:
    Please feel free to send me a PM or email if you have any questions!
    Click Here to Order or Learn More!
    You May Also Be Interested In:
    Solid 8V Audi A3/S3 Quattro Rear Sway Bar Upgrade
    8V Audi A3/S3 Dogbone Mount Insert Upgrade
    Also Available At:
    Achtuning
    New German Performance
    VolksMuller
    Drive Auto Works
    Techtonics Tuning
    We're also giving one of these brand new intakes away for free! You get one entry for joining our email list, and up to 10 additional entry for each friend you refer to the raffle.
    Enter the MQB Cold Air Intake Giveaway Here!
    Established Member Two Rings LOT4R's Avatar
    Jan 12 2015
    Chalfont, PA
    Q: How doest this account for engine movement? Wouldn't it be susceptible to breakage with it being so rigid?
    Aside from that, nice product.
    2015 Audi S3 Prestige: 3M Scotchgard Pro | H&R Spacers 10F & 15R
    Flickr
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Quote Originally Posted by LOT4R View Post
    The coupler gives the needed flex, there is a 2-3 inch gap between the turbo inlet and the end of the carbon fiber tube. I had the same concerns (with this and other intakes) and once installed you can feel the needed flex. I ran this intake all day at the track (5/23) and had no issues and rechecked fitment after each session (I had thermo couplers installed so was adjusting those and had to take the intake off a few times).
    Once I have time to compile all the data I plan on posting the results up!
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Jan 12 2015
    Chalfont, PA
    Quote Originally Posted by aaronz View Post
    Good stuff. Thanks man.
    Flickr
    Jun 10 2008
    Spiders
    Chicago And NJ
    Sep 17 2005
    Fremont, California
    Good question! As Aaron mentioned, the silicone coupler between the turbo and inlet tube allows for sufficient flex, given that the intake is not solid-mounted to the core support. The airbox mounting allows for some movement, as does the coupler, which is more than enough to accommodate engine movement.
    We've been running a much more fragile printed plastic version of this intake in our S3 for about a year now, and it has held up to countless track days, launches, and a number of visits to the drag strip.
    Looking good!
    Sep 17 2005
    Fremont, California
    I recently bought a CPO Mk7 Volkswagen GTI, which shares the engine/turbo setup with the 8S Audi TT & 8V Audi A3. I made it almost a whole week after bringing the car to work to start tinkering. Progress!
    Since the car already had a mystery tune on it, I decided to use the opportunity to do some before and after testing of our X34 MQB Intake. Installation only took about 30 minutes, including the obligatory picture-taking.
    Below is the best run on the stock airbox, compared to the best run with the X34 installed. Even I was pretty surprised by the gains!
    Now, time to switch to our own software...
    - Laszlo
    Sep 17 2005
    Fremont, California
    Thank you for the continued orders! There's less than one week left to enter our MQB X34 Intake Giveaway, and we'll be announcing the winner at the end of next week.
    Sep 17 2005
    Fremont, California
    Congratulations to Corey C in Arizona, who won the X34 Intake Giveaway! Thank you to everyone who participated in the raffle; we'll be sending you a follow-up email shortly.
    Sep 17 2005
    Fremont, California
    A local customer stopped by today with a 2015 Audi S3 to switch to our intake from a competing CF unit due to fitment issues. We did back-to-back comparison dynos of the aftermarket intake he had, the stock airbox/filter, and the 034Motorsport X34 Carbon Fiber Intake, in that order. Modifications are below.
    - Stock Tune
    - Milltek Turboback Exhaust
    All intakes are not created equal, and some may not even yield much improvement over the stock airbox.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Quote Originally Posted by 034Motorsport View Post
    - Stock Tune
    thats cool, but really, who would care about 6hp/7tq. at that point its more about looks than function and i think both look great :)
    spoke with laszlo on facebook and it seems with stage 2 the gains are there, especially in the higher rpm where it doesnt make more peak hp, but instead carries that peak further out
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Sep 17 2005
    Fremont, California
    Update from Laszlos Mk7 Intake install
    More Intake Stuff
    I installed our X34 Mk7 GTI Intake about a month ago, and was thrilled with the gains.
    With no changes besides the intake, the Stage 1 2.0T picked up 9 wheel horsepower and 9 wheel foot pounds of torque at peak, with peak gains of over 25 WTQ and 30 WHP towards redline.
    While we already tested modifications to the inlet duct at the core support extensively last year, it seems that people are still interested in this modification even if it doesn't make much (if any) power on stock turbo setups. So, we printed up this neat little part for some further testing.
    The extra sound is pretty nice, and we'll be evaluating it further in the coming weeks. :)
    Sep 17 2005
    Fremont, California
    Intakes are back in stock ready to ship! Place your order today for the best intake out on the market.
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    Is the provided filter a dry filter or oiled filter?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by 1S32K16 View Post
    Great question! The filters we use are oiled.
    Sep 17 2005
    Fremont, California
    Feb 18 2016
    Infiniti QX60
    SD
    Off topic, but when can we expect to see an oil catch can for 8V?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by hbracer93 View Post
    We currently have those in development! Once I get an update I will let you know :)
    Feb 18 2016
    Infiniti QX60
    SD
    This is good news. I'll be waiting.
    Sep 17 2005
    Fremont, California
    Weren't able to make it out to Summerfest? No worries we got a video with some of the action!
    Sep 17 2005
    Fremont, California
    We just came back from Fastivus! Who saw us out there?
    Oct 16 2012
    pa
    Just ordered this intake, plan on setting up a day at the dyno for independent results as well as track results :)
    Active Member One Ring P230james's Avatar
    Aug 21 2016
    2006 Mazdaspeed 6
    Florida
    That's impressive dyno results. Well done! I'm curious, is there much of a total weight difference between the OEM air intake components and the 034 air intake components?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by saxon View Post
    Sounds good! Let us know how the intake performs!
    Quote Originally Posted by P230james View Post
    At this moment I do not have an answer. I'll talk to our development department and see if I can get a weight for the oem one and the 034Motorsport intake.
    Sep 17 2005
    Fremont, California
    We just posted our recap of Fastivus!.
    034Motorsport at Fastivus!
    Jul 24 2014
    Sweden
    Hi!
    Read your reply on another forum about 'having something in the works' on request of a cheaper plastic version of the intake.
    Any update on this??
    Would almost certainly wait and buy this if released within this year.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by StigThe View Post
    Hi!
    It is still currently under development. I believe we have the 3d printted version out and we are test fitting everything to make sure it fits. It will still be a couple of month before it is released.
    Jan 12 2015
    Chalfont, PA
    Oh snap! Where can we get the matching CF engine cover?
    Flickr
    Sep 17 2005
    Fremont, California
    We will have those available shortly!
    Sep 17 2005
    Fremont, California
    Who's going to Big SoCal Euro?
    Let me know if you need any specific parts and we can bring them down to the show!
    Sep 17 2005
    Fremont, California
    Thank you for all the orders!
    Sep 17 2005
    Fremont, California
    A look back at Big Socal Euro! Did any of you swing by the booth?
    BIG SOCAL EURO 2016 | AN EVENT FOR ALL
    Sep 17 2005
    Fremont, California
    I know many of you have wanted to hear sound clips of our X34 MQB Air Intake... Here's an awesome video of Aaron's 2016 Audi TTS putting the intake (along with many other 034Motorsport Go Fast Parts) to the test at a regional Autocross event. Enjoy!
    Aaron's TTS is running just about every 034Motorsport upgrade available for the MQB platform. :)
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    [/LIST]
    Looks like a lot of fun!
    For anyone local we have a large inventory of 034 parts .
    Thanks,
    Alex.
    Sep 17 2005
    Fremont, California
    This week only, we're offering Free Domestic Shipping for all orders over $75, and Free International Shipping for all orders over $500!
    Click Here to Get Your 034Motorsport Go Fast Parts!
    Terms & Conditions: Free Shipping Promotion valid for retail customer orders placed between 12:01 AM Pacific Time on Saturday, October 15th and 11:59 PM on Sunday, October 23rd. Cannot be combined with other Discounts, Promo Codes, Gift Cards, Quotes, or Coupons.
    Cannot be applied to orders retroactively. Must select Free Shipping option during checkout.
    Sep 17 2005
    Fremont, California
    Sep 17 2005
    Fremont, California
    Trailing arm bushings have been updated! They will now come with the complete arm with the bearing pressed in to save you some time and money!
    Features:
    Fully Assembled with New Factory Steel Trailing Arms - Simple Bolt-In Installation!
    Genuine Aurora Spherical Bearings Featuring Teflon Race Lining
    Billet Aluminum Bearing Holders - Anodized Black
    Stainless Steel Bearing Spacers
    Improved Handling & Road Feel
    More Precise & Predictable Handling
    Fully Rebuildable
    SPHERICAL REAR TRAILING ARM KIT, MKV/MKVI VOLKSWAGEN GOLF/JETTA/GTI/R & 8J/8P AUDI A3/S3/RS3/TT/TTS/TTRS
    Sep 17 2005
    Fremont, California
    How was everyone's Black Friday/Cyber Monday buying extravaganza! I hope no one missed out on our sale :)
    Sep 17 2005
    Fremont, California
