Results 1 to 2 of 2
    May 17 2016
    Northern New Jersey
    2001 a6 2.7t 122k auxiliary fan control module replacement
    Hey guys jus recently the fan behind my radiator slightly to the left (auxiliary fan) would not turn off even with my vehicles engine being off.
    it was still running full blast. i did some research and found others had same problem but different vehicles and years. Most of the posts i seen
    said it was a '219' relay under the ecu that could probably be bad however my vehicle does not have that particular relay. i took it to a mechanic
    and he says it isn't a relay its actually the FAN CONTROL MODULE that needs replacing...price is pretty hefty tho...how hard is it to replace on my particular
    vehicle? do i need to put in service position? where exactly is it located?
    Established Member Two Rings MrWalker's Avatar
    Mar 22 2016
    Laredo, Texas
    hey not sure on your on your issue but i would recommend buying the bentley manual for your vehicle. it breaks everything down that you want to know with service. GL with your service. oh and the manual ran me $75 bucks off of ECStuning.com. let us know how it went.
    2003 Audi A6 2.7T (AT) Stock for now
    2005 VW GTI 1.8T (MT) Stage 1 ECU by APR/ Cold Air Intake/ BOV/more to come
    2007 Chevy Suburban Stock
