Results 1 to 40 of 61
    Dec 21 2015
    Long Island, NY
    Angry A4 B8 Timing chain job P0016
    Hey guys,
    So for the longest time my car was getting misfires and acting crazy. After about 8 months we finally diagnosed it as a stretched timing chain. I finally got the job done after working on it for quiet a while. I start the car and it runs 100% smooth, no misfires, no shaking, no nothing! I turn it on and off a few times and it feels great. So I decide to put the rest of the car back together. After everything is together I start the car up and let it run for 30 min or so. The car ran great. I turn it off and go to turn it back on and now it won't start. I scan the car and see that it flags a P0016 code (camshaft position sensor). I clear the code and it starts up perfectly fine and is running smooth again. I turn it off and then it won't start again and the same code comes back. Now my question is, what could be causing this code?? It is starting to drive me nuts!!
    I read on another forum that there is something you need to do in vagcom after doing a timing job, is this true? They didnt give much details so I'm still kinda lost.
    Any help would be really appreciated.
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Did you replace the timing tensioner with the chain?
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Dec 21 2015
    Long Island, NY
    Quote Originally Posted by Allowencer View Post
    Yes sir
    Jun 12 2013
    I dont think there is anything within VAGCOM for this. If you're getting that code, then usually something is 'off' still.
    Build Thread
    Dec 21 2015
    Long Island, NY
    So I should be going back in to check timing?
    Jun 12 2013
    That's a good place to start for sure. Did you take any pics on the re-installation?
    This is what your timing should look like:
    Notice the 'marked' links are on each sprocket marking point? This is with cylinder #1 @ TDC too.
    Keep in mind, it can take up to 20 some revolutions before the marked links will line up to the corresponding marks, that is, if the timing is setup properly. This is because the sprockets have and odd tooth count between all of them.
    Also, how were you able to establish timing? Do you have a pair of cam sprocket locks (one is pictured above in my pic)? If not; how did you rotate the cams slightly to get them into position properly to establish timing?
    Build Thread
    Dec 21 2015
    Long Island, NY
    I didn't have the specific Audi tools but I had a few things I used for other jobs. I was able to get the timing to match up perfectly with the marks on my valve cover and the points on the chain.
    Jun 12 2013
    There aren't any marks on the valve cover for a CAEB motor. The marks are on the sprockets themselves. You have an A4, 2.0 right within 2009-2011 year?
    Build Thread
    Dec 21 2015
    Long Island, NY
    Yes. Mine shows 2 marks on the valve cover. They seem to line up perfectly. Maybe a previous owner did that?
    Jun 12 2013
    Here's a pic of the valve cover in the areas of the sprockets - there's no marks on it at all. On older gen Audi's, the marks used to be on the valve cover, but not on the B8 motors.
    To that point, me, personally, I wouldn't trust what someone else did.
    I was helping out another forum member and the marks he found were paint marks on the sprockets when the dealership did his stage 2 oil consumption. It's a fast shortcut on getting the timing back on right as you don't have to rotate the motor over several times and the timing chain won't be pulled off of the crank. You can take a lot of shortcuts when other things aren't being replaced. I've seen other forum members here post pictures of it when their car was at the dealership and they let them take pics.
    Build Thread
    Dec 21 2015
    Long Island, NY
    Ya see I was lining the marks on my cams to the chain link marks which lined up perfectly to the valve cover marks. Either way timing must have been done correctly otherwise it wouldn't be running as smooth as it is.
    Jun 12 2013
    How did you torque down the intake magnetic valve? What tool did you use and torque setting?
    Do you have a vagcom? Check to see if you get values from the cam position sensor.
    Build Thread
    Dec 21 2015
    Long Island, NY
    Got me there. Can you go into a bit more detail? That may be my error.
    Jun 12 2013
    Did you remove the cam bridge / cam control assembly which is the assembly right in front of both cams. If you did, on the intake cam, there's a valve that requires a special tool to remove.
    Also, you can be a link off and the car will still seem to run fine.
    Build Thread
    Dec 21 2015
    Long Island, NY
    Yes I had that tool. I was able to take that out fine. It needs to be torqued when you put it back in?
    Jun 12 2013
    Absolutely it does! It's a key critical component. That valve is left hand threaded and should be torqued to 35 Nm / 26 fl lbs
    Any drivetrain, valvetrain, drive line component should always be properly torqued. These are the most critical fasteners within an engine.
    I find it odd that you did all of that work and didn't take any pictures.
    Build Thread
    Dec 21 2015
    Long Island, NY
    I guess I'll be taking off the front cover and torquing it. I noticed it was reverse threaded when I went to take it off.
    Haha ya I usually don't take pictures of anything. I should probably get in the habit of it.
    Jun 12 2013
    I'd triple check your timing too. Ensure the 'marked' links match up to the markings in the sprockets, not the pseudo marking in your valve cover; the crank pulley's notch needs to match up to the mark on the timing cover too.
    Build Thread
    Dec 21 2015
    Long Island, NY
    Will do. Thanks for all the help so far.
    May 17 2016
    Hong Kong
    Hi Abu_boost , I ran into the same issue as you do. I have tote same P0016 code , after timing repair job. Can you let me know how you fix the issue at last?
    Dec 21 2015
    Long Island, NY
    Will do!
    Dec 21 2015
    Long Island, NY
    I triple checked timing and it's on the money. I took it apart and realigned it. Any other ideas?
    Jun 12 2013
    How far off was your timing when the chain jumped? Did you check this before tearing it apart?
    Did you have any other damage? Is your intake cam's lobes all in good condition?
    Have you removed your intake cam sensor and cleaned it off? It's possible it has picked up magnetic debris and having a hard time picking up the reluctor wheel on the intake cam.
    I'm also concerned that you might have overtorqued / damaged the INA valve on the intake.
    Build Thread
    Dec 21 2015
    Long Island, NY
    The timing chain was hardly off but it was stretched enough. No other noticeable damage. Everything looks good. Inspected all the valves as well.
    I'm gonna try and change the camshaft position sensor and see if it makes a difference. The thing is the car didn't throw a code until we let it run at idle for 30 min.
    I haven't driven the car yet at all. I'm going to change the sensor then try and take it for a drive. The car sounds good. Isn't shaking or acting up. I even read it with a scanner. There is absolutely no misfires now at all.
    Jun 12 2013
    What you say 'hardly off at all'; what does that mean? 1 link? 2 links?
    Build Thread
    Dec 21 2015
    Long Island, NY
    Not even a full link. The car was still running smooth, it was just throwing misfires at start up after it was warmed up.
    Jun 12 2013
    That doesn't make sense. Either it's a link off or it's not... It's not possible to be half a link off.
    Build Thread
    Dec 21 2015
    Long Island, NY
    I'm doing the work with a friend who is a bit more well versed. I'll find out exactly from him. Last he told me it was stretched out enough to make a difference but wasn't far off.
    Jun 12 2013
    I wouldn't think a stretched chain would cause this as it would have to stretch significantly to cause an out of timing condition. If it actually stretched that much, it would break in my opinion.
    I thought you were doing this, now it makes sense based on the gap of information. No offence, I'd be questioning how 'well' your friend knows how to work on VAG motors.
    Build Thread
    Dec 21 2015
    Long Island, NY
    We are doing the work together. He's a good mechanic, but working on this car was definitely a learning experience.
    Dec 21 2015
    Long Island, NY
    I stopped by my local audi parts to pick up a cam position sensor.. I was talking to one of the mechanics, he told me after doing a major job like that they might have to reprogram the computer. Whats your thoughts on that?
    Jun 12 2013
    It's not stating in the service manual at all. Some cars use specific harmonics in order to determine cam timing and may require what is called a 'case learn'. I have not run across this on the Audi's.
    Build Thread
    Dec 21 2015
    Long Island, NY
    I changed the camshaft position sensor. The p0016 went away.
    But now onto other issues. It's throwing misfires in all cylinders and a p2279 code.
    Dec 21 2015
    Long Island, NY
    It wasn't acting like that before when I had the p0016 code
    Jun 12 2013
    Did the new cam position sensor have a new o-ring on it?
    Sounds like you have a vacuum leak now
    Glad to hear the new sensor took care of the p0016 code. Now you have to find the vac leak.
    Build Thread
    Dec 21 2015
    Long Island, NY
    Yes it had a new o-ring.
    A lot of people on here are pointing at a faulty pcv? It was changed about 6 months ago, could it be bad already?
    Jun 12 2013
    It could be. With a vacuum leak, any area around the cylinder head, any line is all within scope; that includes the PCV sytem
    Build Thread
    May 02 2011
    '15 A6 3.0t, '14 GMC Denali Duramax, '12 F150 EcoBeast
    Casper, Wyoming
    DON'T TRUST THIS!
    A new CPS took care of my CEL as well and 6 days later with no warning the timing assembly let go!
    If you're getting the P0016 code you need to at least pop open the inspection hole in the top timing cover and look at your chain and tensioner. I bloody well wish I would have, would have saved me a ton of time and money.
    * I know you know this Allowencer but I'm putting it up here for the people who will come along later and read this.
    Dec 21 2015
    Long Island, NY
    Quote Originally Posted by buelldozer View Post
    DON'T TRUST THIS!
    The code came up after the timing chain and tensioner job was done. We went back and triple checked timing to make sure it's 100%.
    Jun 12 2013
    Valid point buelldozer - good note for the community.
    As Abu_boost mentioned, him and I have been dialoging this since he's been rebuilding.
    Build Thread
