Page 1 of 5 123 ... LastLast
Results 1 to 40 of 164
Thread: VR Tuned 4.0T
    VR Tuned 4.0T
    VR Tuned ECU Tuning Box Kit Audi S6 C7 4.0T
    Audi’s 4.0L twin turbocharged engine that is found in the new S6 is a menacing beast with 420bhp stock. Audi S6 Tuning can yield some very impressive gains via a ECU flash or tuning box. For those looking to add some no hassle, warranty safe power, the VR Tuned Tuning Box is the way to go. Plugging into factory sensors, the Tuning Box takes the Audi S6 4.0L to 540bhp and 700nm of torque! Thats quite the difference! You can see the dyno graph of our test car we did here at Vivid Racing. The tuning box has a dial on it which can be adjusted up or down for different octane used. As seen here, the dial is set to 5/6 for 93 octane cars and for 91 octane, we recommend 3/4 setting. This tuning box harness fits the other 4.0L twin turbo engines such as the Audi A8, S7, and more.
    Product Information
    New from VR Tuned is this performance Tuning Box kit for the Audi S6 4.0L TFSI turbocharged engine. This tuning box kit is a plug and play solution to tune your cars fuel, timing, and boost giving you up to 40% more power and 20% fuel savings. The VR Tuned ECU Tuning Box Kit gives your Audi 4.0L TFSI engine a gain in power from 420bhp to 540bhp gaining you 120bhp!
    Plug and Play for easy removal to avoid warranty issues
    Designed for turbocharged vehicles only
    Does not lock to vehicle or VIN
    Harness has OEM style connectors, no splicing or cutting
    Tuning Box features an aluminum weatherproof case
    Digital Microprocessor Controlled
    Installs in 5 - 45 minutes depending on vehicle
    Proven power gains
    3 year warranty on parts
    Tuning Box cannot eliminate CELs from catless or high flow cat exhaust parts
    On the back of the box is a removable cover with dial settings you can adjust. This is to allow small adjustments to the power setting so the box can work correctly in different climate conditions and on different quality fuel.
    Send us a message today for special in stock pricing and or questions.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Interested in this! I know most piggybacks are laughable for this engine but maybe this one is the real deal. Does this work for 2016 MY??
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Quote Originally Posted by Djpeaksd View Post
    Sure does!
    I will PM you a price.
    Feb 01 2016
    Encinitas, CA
    Awesome I'll look for your pm
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    I don't see the dyno graph - could you please link me to it?
    I also don't see this item on your website, but maybe I missed it?
    TIA.
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Quote Originally Posted by zcd2.7t View Post
    TIA.
    http://www.vividracing.com/blog/vivi...-with-vrtuned/
    Sorry about that!
    Feb 01 2016
    Encinitas, CA
    A big appeal to me on this is to avoid a TD1 but after looking into it, it seems that Audi could go through logs and still detect a tune whether it was a re flash or piggyback. Anyone have any thoughts on that?
    I personally used to work on these cars as an Audi tech at the dealer. The only way for the system to pick it up is if you "reflash the ECU fully with software" or leave this plugged in when you go into the dealer. They will run what's called a specified actual comparison on the vehicle it will compare the current software level of the vehicle to the software in Germany that is supposed to be on the vehicle from the factory as per the Vin number. With this there really isn't any concern as long as you plug unplug it when you going to the dealer.
    May 24 2015
    NW
    Aren't there logs of boost, timing etc? Could those be analyzed and cause the tech to think there was a tune at some point if it's over boosting?
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    I think it is still possible. I think the engine records parameters for how much boost, etc. the car gets over the last 50-100 miles. There has been a lot of speculation about this but no hard evidence AFAIK. If you blow your engine and break down on the side of the road, even if you remove it, the data is still theoretically recorded in that black box. Sure it won't show up on a SA/GFS scan, but if you need a serious engine or transmission repair, Audi engineers will do a review of the ECM, and they could find said data. I don't mean the techs working on your car, I mean people above them that are trained to look for these types of interventions on the engine.
    You have to pay to play. This is a safer bet than a true ECM flash, but IMO it still leaves potential for discovery if things go sideways. However it is significantly more convenient, and cheaper, to just remove this box than going to your dealer and re-flashing to stock.... Pros and cons. Play at your own risk!
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by hubris View Post
    Yeah I think you are exactly right, plus having a good relationship with your service advisor is a plus as well! Since you mentioned it I would like to bring it up, have we heard of any 4.0T's actually blowing up or having major issues due to a tune on this site?
    Agree with both, However Audi or any manufacture cannot deny a warranty claim just because. If they can pinpoint something to the T and prove THIS is exactly what has caused it then that would be a different story.
    Nothing is ever 100% however, I have tuned and modifed these cars personally for the past 2 and a half years and have no ran into any issues yet.
    Regards,
    Adam
    Jul 21 2004
    South Florida
    There are no "logs" for the dealers to go through. The TD1 process has been outlined by Audi. It is a spec vs actual scan as was stated by vivid.
    If Audi were to increase their level of detection, they could conceivably event record. Recording events already takes place. We know of them by the name of "soft codes" and "trouble codes." Those are simply recordings of events that have taken place (they are timestamped and tell the frequency, etc). One event that gets recorded that can lead to warranty issues is the "max rev limited exceeded" event if you were to misshift or "money shift" your car. Audi will not be paying for that.
    It is conceivable that in the future Audi could also record other "max level exceeded" events such as vehicle speed (if you had an OEM top speed limiter removed and exceeded it), engine rpm (if you were TCU tuned and exceeded factory rev limits), and even max load/torque values, which everyone who was flashed would be screwed on. The kicker is that with a piggy back the ECU is tricked into recording lower than stock boost. This is so the ecu thinks the car is making less boost than it really is making and the ECU will then take over and attempt to make more boost. So "max boost" and "max load" logs would not be exceeded using a piggy back. But again, this is all moot because as of right now there are no events such as this recorded.
    Mike
    2018 Audi S5
    Gone-
    Quote Originally Posted by bhvrdr View Post
    It is conceivable Audi could also record other "max level exceeded" events to such as vehicle speed (if you had an OEM top speed limiter removed and exceeded it), engine rpm (if you were TCU tuned and exceeded factory rev limits), and even max load/torque values, which everyone who was flashed would be screwed on. The kicker is that with a piggy back the ECU is tricked into recording lower than stock boost. This is so the ecu thinks the car is making less boost than it really is making and the ECU will then take over and attempt to make more boost. So "max boost" and "max load" logs would not be exceeded using a piggy back. But again, this is all moot because as of right now there are no events such as this recorded.
    Mike
    Thanks Mike for chiming in you elaborated on exactly what I wanted to explain further in depth.
    Jul 21 2004
    South Florida
    Quote Originally Posted by vividracing View Post
    My pleasure. BTW, if you can get some 1/4 mile times/traps, it would probably be even more meaningful than dyno sheets, IMO. Looking forward to learning and seeing more.
    Mike
    2018 Audi S5
    Gone-
    Mike
    For sure! We are going to get all of that posted as soon as we've got a guy that does more than just runs around the street ;)
    Account Terminated Two Rings
    Apr 26 2016
    London
    How does your MAP clamp differ from Chipwerke's? How does it compare in terms of price?
    Veteran Member Four Rings SilveR316's Avatar
    Jun 02 2013
    Downtown Toronto
    Does this work with the C7.5 as well? The newer model years have 450hp stock as opposed to 420hp the older model years had.
    2017 S6|Sepang Blue|Black Optics|Silver Mirrors|ASC WiFi Module|AWE Exhaust|034 Drivetrain Mounts
    2014 S4|Prestige|Estoril Blue|6MT - AWE 102mm|Alu Kreuz|KW H.A.S.|SPC Control Arms|20x9.5 Vorsteiner V-FF 102|Vorsteiner Front Spoiler|Deval Valence - Build - SOLD
    Quote Originally Posted by SilveR316 View Post
    Yes it does work for this as well, and you are correct.
    Jun 02 2013
    Downtown Toronto
    So what are the final numbers for the C7.5? Is it the same end result as the C7, or is it 30hp more? Do you have a dyno for this?
    Quote Originally Posted by silver316 View Post
    so what are the final numbers for the c7.5? Is it the same end result as the c7, or is it 30hp more? Do you have a dyno for this?
    kw 331 417
    bhp 450 567
    nm 550 699
    Jan 19 2010
    MI/CA
    ...Sorry about that!
    Thanks, I guess. No pricing anywhere to be found, nor any actual performance stats.
    Why do I need to PM you for pricing? There are almost 5,000 "tuning box kits" on your site with pricing, but nothing about this particular kit, even though the blog post is dated 2014....
    It all seems a bit odd to me...
    Feb 01 2016
    Encinitas, CA
    Guys I'm considering being the guinea pig on this one and see how this piggyback works. Everything I've read looks like a solid company. I don't think anyone on this forum has this tune, well I haven't seen anyone with it. If anyone has feedback on it please let me know.
    Mar 18 2011
    Denver
    https://www.vividracing.com/catalog/...150785402.html
    Veteran Member Three Rings Demandred's Avatar
    Jul 25 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    i too would just like a price listed - maybe even a Group Buy offered to Audizine members
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
    Hello there!
    I will send you some more info now
    Quote Originally Posted by Demandred View Post
    We would be glad to entertain a group buy!
    Anyone who is interested in being a part of this please post here and or send a message and I will get this put together.
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    I have a c7.5 3.0T. Austin might remember me, I asked him a few times about the VR tuned box for me. The C7.5 engine is quite different. Any chance you might have tested your piggyback on a c7.5?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Quote Originally Posted by agent47 View Post
    Hello there,
    As far as how this hooks up to the vehicle will be the same between the two but would like to confirm. Can you PM me a picture of the sticker on your ECU ?
    Regards,
    Adam O'Hare
    Jul 21 2004
    South Florida
    Hello there,
    Regards,
    Adam O'Hare
    The 2016 A6 CREC engine is not the same as the 2015. The MAP sensors are also not the same. The CREC engine uses new digital transfer protocol called SENT for their sensor data.
    Mike
    2018 Audi S5
    Gone-
    PM's sent!
    Jan 27 2016
    '14 QX80, '12 FJ Cruiser (Heavily modded)
    Denver
    Im very curious to get feedback from real users of this solution. It looks promising.
    Current:
    '13 S7 (Innovation, B&O, LED's, AWE Exhaust, RS-Grille) -- '12 FJ Cruiser (Heavily modded) -- '14 QX80
    Gone but not forgotten:
    2014 Porsche Carrera S -- 2014 Toyota 4Runner -- 2002 Acura TL-S (My first 'luxury' car)
    Quote Originally Posted by jfeger View Post
    More Feedback will be coming soon! I've sold out of my inventory on these. More coming from Germany asap
    Established Member Two Rings dogears's Avatar
    Sep 05 2014
    2016 Daytona Gray S6 w/ Arras Red Designer Interior, Sport Package, Black Optics, Bang and Olufson, Driver Assist, Night Vision, and Cold Weather.
    Quote Originally Posted by dogears View Post
    Feb 01 2016
    Encinitas, CA
    Ok boys I just pulled the trigger on this piggyback!!! I should have it next week and I will let you know what I think. Ill do a video for install and some pulls in the car stock vs. with the piggyback installed.
    Sep 05 2014
    Sounds great!! Looking forward to the post and your thoughts!
    Just a heads up keep a look out on this thread for a VERY Satisfied customer with this product :) we love when we get those calls !
    - - - Updated - - -
    Thanks man! We appreciate you taking the time to do a video as well.
    Can't wait to see it! are you going to post a reaction of your face ;) ?
    LOL
    Jun 03 2016
    Earth
    Tuning Box First Impressions, Thoughts, and Advice
    So, my VR box arrived yesterday. It came packaged in a bag with the SKU. It was missing any mounting hardware (wire ties), fortunately I had a bunch at home so no biggie. Note to Adam, make sure fasteners included. I had printed out the instructions from the web site. The unit came with nothing except the box, loom, and "go back to stock" plug. My advice to VR is to include the fasteners and instructions. Maybe even a fancy box since the unit is not cheap.
    On to installation. I shut the car off and popped the hood. Let it sit with the doors locked, as instructed for over 5 minutes. I then popped the engine cover off. This was a piece of cake. I laid out the units loom in position and proceeded to unplug the sensors and install the VR loom in their place. Everything was going well until I got to the MAP sensor. It was really hard to unplug since it is difficult to get a good grip on it with its location. I wound up using a flat head in the connector to unlock it and then it was easy. Instructions on how to unlock the sensor plugs would have helped. I wound up with a tiny skinned knuckle on one finger accessing that plug. It is doable and really not that hard. So no worries...... I wound up using wire ties to install the box in the engine bay on the drivers side up near the brake hardware on the firewall. Anyone with a better suggestion, please advise. I think VR should include suggested mounting in the instructions.
    I set the box to "5" on the dial. It ships at 6. I run 93 octane only. My first test drive was not very conclusive as there was a lot of traffic around the neighborhood. I was only able to push it from a roll in 2nd. Felt strong. About an hour later, I had to run out and I did get to punch it a bunch. It was definitely much stronger. I did not feel the mass of the car as much. Before install, I would feel the weight holding the car back. Now, it pulled much stronger so the car felt lighter. I then stopped and set it on 6. Not sure whether it was better, I put it back to 5. This way I am more comfortable with engine not pulling timing or boost to protect itself. Last night, I had to do 20+ miles of highway driving. I did a whole bunch of testing and I feel that it made a large noticeable improvement. There were no adverse throttle issues or anything other than more response and pull. Not sure what the gains are but I would not be surprised if it were north of 50-60hp. It was that noticeable. I found myself nailing it more just to feel the power.......
    I will do more testing this weekend, but so far, I am satisfied.
    Disclaimer: I am a long time forum member posting under a new username to avoid any chance of big brother slapping a TD1...... That is why this is the only post, not shilling......
    - - - Updated - - -
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    1/ Plug laptop into OBD port.
    2/ Click stage 1 tune.
    Lots of extra power. No skinned knuckles...
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
