Results 1 to 25 of 25
Thread: Comparable ECU
    Mar 21 2016
    Colorado
    Comparable ECU
    So new ecu is chipped. Swapped in 5psi fpr and car runs rough. I noticed new ecu has a N on end and mine has a P on the end. Will this ecu work? Any help appreciated.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    if it is chipped to your configuration ie quattro/fwd auto/manual it will work
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Mar 21 2016
    Colorado
    I'm wondering if it just needs to be driven a bit to reset.
    Dec 13 2010
    FL
    Quote Originally Posted by Coupe-vr6 View Post
    giac k04 file? only one im aware of that uses 5 bar FPR.
    was that a new or used fpr you swapped in?
    Mar 21 2016
    Colorado
    New fpr. Neuspeed.
    Mar 21 2016
    Colorado
    Dec 13 2010
    FL
    hmm. idk anything about that file. i would assume it also use stock aeb injectors like the giac file.
    when you say running rough, is it throwing misfire codes? you have any way to check your fuel pressure?
    Mar 21 2016
    Colorado
    Just boggy at mid to higher rpms almost like in limp mode and when coming back to idle Boggs down and comes back up to idle.
    Mar 21 2016
    Colorado
    Tried running with stock fpr same symptoms.
    Dec 13 2010
    FL
    sounds like boost leak
    dont do that. you are starving the engine for fuel.
    i have a strange feeling you dont have a boost gauge. if so, is it seeing requested boost?
    what file were you running on the car beforehand? ran fine(y/n?) did the car sit for a while? i mean, it can be anything, but without performing any kind diagnostics, fuel pressure boost pressure codes etc, we really have nothing to go off here.
    Mar 21 2016
    Colorado
    Yes I have boost gauge. Was just running stock management before. Car ran fine max boost was about 6psi. Have not driven it since I put new ecu in so not sure about current boost.
    Mar 21 2016
    Colorado
    No sitting or anything odd.
    Dec 13 2010
    FL
    i would start with a boost leak test and scan for codes.
    stupid question lol you do have a k04 right? not sure if a k04 file would run rich enough on a k03 and cause these issues
    Mar 21 2016
    Colorado
    Yes on k04.
    Mar 21 2016
    Colorado
    Ya I'll try boost leak test.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by GrapeBandit View Post
    Shouldn't make any difference at idle.
    I'd like to see long term fuel trims after you drive it for a bit. Keeping an eye on the instant trim to make sure it's safe to do so, of course.
    Mar 21 2016
    Colorado
    PO had pretty much same set up. I have k04, exhaust, forge splitter, stock injectors, intake and 5 pound fpr. Wonder if car just needs to be drivin on for a bit to re configure. I'll have to try it and try to video symptoms.
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    run an TBA, might help since the ECU was reset
    one of those days... every day.
    Remember to change your blinker fluid it may go bad on you!
    May 16 2016
    gauteng
    need information
    how do i reconfigure my old ecu because my ecu is configure for an automatic and i change it to manaul
    Nov 03 2011
    All Over!
    Quote Originally Posted by carel View Post
    Soft coding via VCDS.
    1986 Type 85 Audi 90 quattro
    Mar 21 2016
    Colorado
    Tba?
    Dec 13 2010
    FL
    Tba?
    throttle body alignment, but you need VCDS or bring it to the dealer to get it done
    Sep 13 2014
    somewhere
    Yea throttle body alignment, its a simple process that takes little time to do and does wonders for a car that hasnt done its own checks, the tb can malfunction causing rough acceleration or in my most recent case stalling the car when u press the gas pedal if ur gonna do a ecu swap i recommend getting vcds to check fault codes
    Mar 21 2016
    Colorado
    Would it need tba even if it's aeb. Drive by cable?
    Sep 13 2014
    somewhere
    Yea, Mine is an 99 AEB Sometimes it just doesnt align correctly
