Hello all,
I recently did a bunch of engine work and the 1.8t oil pump and such. This is on a 2.0t.
I recently FINALLY got my first start up and all is well outside of chugging and dropping idle at start up. Oil pressure is great and everything was running well after I replaced the HPFP fuel pressure regulator valve.
I had a code for that valve, mass air flow, and exhaust related CEL.
After the CEL came out the engine smoothed itself out and idled fine. I replaced the Fuel pressure regulator valve and reset the CELs to see if it would come back. When I started up the CEL was gone but the chugging was back. It is not throwing any codes yet but eventually stalls out after about a min of trying. Oil pressure is fine still.
I did not have any mass airflow codes prior so I suppose its possible that I ruined that while doing the work but I don't see how.
Its obviously a sensor causing it to chug then once the sensor cuts itself off (or whatever it does) the engine runs smooth.
Sorry if this is hard to follow. Any advice? I am going to try to get it to throw codes again so I can see if the fuel pressure code went away but I am leaning to me either missing a plug or the mass air flow.
Another option could be the car reading the o2 from the test pipe but I have the JHM flash which I am going to install that will take care of that.
