Greetings audizine.
I'd like to organize my thoughts and information in this thread for others viewing and opinions. Im in the midst of a BT 1.8 build/swap for the avant.
Little background on myself and the car, Im a 21 yo red seal automotive mechanic. I purchased this car 4 years ago as a high school graduation present for myself. She has come a long way, but i will simply let the pictures do the talking.
Picture from the day i picked it up. Clean, 03 Avant 5spd Quattro, black interior, 170,000 kms
Didnt take long for the modifying to begin. H&R springs and wheels to start.
As the car progressed:
Keep in mind this is my daily.
Bi-xenon S4 lights
Winter Mode:
And These resemble how she currently sits.
Onto the good stuff. I recently purchased a proffesional, freshly built 1.8l AMB short block with a rebuilt cylinder head from a private seller. He was able to provide me proof of parts, as well as labour to do the work. Knowing I was taking a bit of a risk, I decided this was the best opportunity to begin a BT build for the car. Im shooting to maintain as much driveability/reliability as possible, while looking for around 350-400 AWHP.
Im looking for others feedback on some of the parts I need to complete this build. Specs are as follows.
Engine:
1.8l crank, ground and polished
Manley H beam connecting rods
Je pistons 81.5mm bore 8.5:1 Compression
Block and cylinder head hot tanked, cleaned, painted
New oil pump, pickup, chain, seals etc.
Cylinder head was rebuilt to oem specs, valve grind, pressure tested
OEM audi cylinder head gasket
ARP head studs, cam bolt, crank bolt
IE manual tensioner belt kit with continental belt
Fluidampner front crank pulley
New thermostat & coolant flange
Engine ventilation:
Vent to atmosphere
Turbo/ Manifold:
EFR 6758 .64 ar vband
Pag parts ss vband manifold
All custom stainless braided oil/coolant/lines
Fuel:
Return style fuel conversion using AEB fuel rail
Bosch 040 pump
034 drop in pump kit
Adjustable fpr
Injector dynamics 1000cc
-6 AN stainless braided lines
-6 modified fuel filter
Clutch:
JHM single mass flywheel w/ rs4 pressure plate. Stg 1
Mounts:
Density mounts (street) for engine and trans (034)
Rear diff insert (034)
Poly snub mount (034)
Intercooler:
Evolution raceworks competition series
Water/Meth:
Snow performance stg 2 running on a third party AEM map 0-5v input
Nozzle post throttle body
Tuning:
Bische performance
AEM map sender (input to rear 02 signal for datalogging)
B6 s4 maf sensor
Mk7 golf r map sensor
New crank/ cam/ knock/ o2/ coolant & intake temp sensors
Bische has given me much insight into the best hardware for this build, and will be doing the tuning on this car.
Thanks for reading this far.... Heres a couple more pics of the long block.
