Results 1 to 8 of 8
    May 02 2011
    '15 A6 3.0t, '14 GMC Denali Duramax, '12 F150 EcoBeast
    Casper, Wyoming
    Why use headlight bulbs with higher K value?
    So one of my Phillips bulbs burned out. They were 35W 4300K bulbs so I thought I'd try something different. I ordered a pair of 5000K bulbs from HID-Warehouse and put them in. Here's a picture with the Phillips on the left (drivers) and HID Warehouse on the right (Passenger) .
    https://i.imgur.com/9VbabyA.jpg
    After this picture I replaced the drivers side with a 5000K bulb as well.
    I drove the car last night and I'm really disappointed with these 5000K lights, disappointed enough that I'm about to order up another set of Phillips @ 4300K.
    Why do other people do this? What makes the 5000K temperature somehow "better" than the stock 4300K?
    Edit: Also, how in the world can people not see the difference between 4300K and 5000K, it's easy noticeable even in my crappy part daylight picture!
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    People do it because the cooler (bluer) 5000k lights look closer to white and are synonymous with HID or LED lighting, which has a more "refined" and modern look. The problem with halogen lights is that the cooler you go, the less lumens you have, so your old 4300K lights are actually doing it's job of lighting the road better. Personally, I like the cooler look, but not at the expense of performance. If someone wants the HID/LED look, they should get HIDs/LEDs.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    May 02 2011
    Casper, Wyoming
    Well I guess that answers the question. I'm going to order another set of Phillips Extreme Visions @ 4300K and put these things back in their box on a shelf.
    Deactivated Four Rings
    Jun 23 2011
    4300k is the same as Sunlight. And anything higher than 4300k is decreasing in output/lumens. The 4300k it the top of the curve for output.
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    I have 6000k and I love them
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    As noted by JMG, 4300 to 4500K will give you the best lighting performance, with a warmer(less blue) light. To me , all that matters with headlights is getting the the best visibility possible and the OEM colour temp is optimized to do that. I don't think the white or blue colour looks better at all, and I actually find them annoying.
    2011 A4 Avant
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Everything above is true. Once you start going up in kelvin temp, you sacrifice lumens.
    However, don't forget that you have a burn-in time with new bulbs too. You usually need a few hours of illumination before they start to settle into their normal operating range and color.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Senior Member Two Rings Davidx1994's Avatar
    Feb 02 2015
    2019 Macan, 2015 Jetta TDI, 2009 A4 Avant
    Plainville, CT
    I replaced my oem bulbs with Osram CBI.
    They're pricey, but worth it! Much brighter than stock, they are whiter, and will get cooler as they burn in.
    Sent from my iPhone 6S using Tapatalk
