Results 1 to 7 of 7
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Audi A4 B7 3.2L oil leak
    I did my oil change and noticed some oil residue all over the belly pan close to the transmission.
    I also had some misfire going on and decided to check my coils as well. Yeah, there were oil in them.
    But, it seems like the oil isn't coming from the valve cover gasket. ( It had been replaced)
    Decided to look around the engine.
    Drivers side front.
    Timing cover rear.
    It seems like I have leaks from the camshaft housing and timing chain covers. Some more pic with a mirror.
    I cleaned down all the areas with brake clean. I will monitor to see if I get the same results again.
    As for the oil in the spark plug chamber, where else can it come from besides the camshaft housing?
    Any input is very welcome.
    Thanks.
    Waiapasi2006
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    The upper timing chain overs on the back of the heads can be suspect for leaks, so definitely keep an eye on those. Also the main rear timing chain cover as well.
    Not sure about the spark plug chambers. I found a similar issue in two of mine (middle holes) but couldn't figure it out. Thing is, oil in the spark plug holes likely built up over a very long time unless you recently had them replaced.
    2013 Phantom Black C7 S6 Stage 3 | 2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    IG: tyscalzone
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by Quattro 4 Life View Post
    Agreed.
    I did change my VC gasket a few months back. It was mentioned to me that it wasn't in this case the VC.
    I cleaned all the areas up. I'll see what happens next.
    Fingers crossed.
    Sent from my SM-N900P using Tapatalk
    Waiapasi2006
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Quote Originally Posted by waiapasi2006 View Post
    Agreed.
    Fingers crossed.
    Looks to me like a VC problem just because it changed doesn't mean is undestructable. was the VC OEM or Aftermarket?
    Ivan
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by dalmation53 View Post
    OEM.
    I didn't see any oil seeping down from where the gasket seals the cover.
    Waiapasi2006
    Aug 20 2013
    Miami
    OEM.
    but you said your coils had oil in them too? what else can cause oil in the coils? apart from a PCV gasket going bad.
    Ivan
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    From the camshaft housing.
    Waiapasi2006
