Hey Guys,
Been searching for ages on the net and these forums but cannot find the answer to my question. Hoping you gurus can help out.
Scenario and Goal:
- I want to remove the OEM Amplifier on my Audi A4 B8 2012 with Concert Radio (Non Bose and Non MMI). I will be replacing the Amp with a DSP and Amplifier.
- I DO know that I can use the High Level Outputs from the OEM Amp however I want a cleaner signal into the DSP and less equipment in the car. There are plenty of write ups about the high level output wiring and colors - I don't need this.
Challenges 1: I want to know what the NON High Level wires are in the OEM Amp harness. The twisted pair wires are as follows:
Orange / Violet -- Orange / Brown : Can Bus (Purpose: Switch on amp, Other ?)
Green / Black -- White / Black : Audio ?? (??)
Green / Blue -- White / Blue : Audio ?? (??)
Green / Yellow -- White / Yellow : Audio?? (??)
Red / Violet -- Brown / Violet : Audio ?? (??)
Challenges 2 : What will not work if I remove the amp from the system.?
FYI - If I have unplugged the harness from the OEM Amp and the radio turns on and seems to function normally
Does the CAN BUS Serve any other purpose for the amp?
Challenge 3:
Best place to get Remote Turn on for DSP?
Thanking you in advance!!
