Results 1 to 2 of 2
    Senior Member Three Rings rocket5979's Avatar
    Apr 19 2013
    Fox Lake, IL
    FS: Cam Adjusters, Actuators, Fuel Rails, Fuel Injectors, Knock Sensors, Ignition Coils, Etc... - No Longer Available
    All items came from a 2004 S4 with 72,000 miles and were in good working condition when pulled. Here is the list and asking prices. Buyer pays for shipping.
    Cam Adjuster: $150 ( I have one that is functional but could use the JHM rebuild kit to freshen its engagement slot up)
    Cam/Variable Valve Timing Actuators: $150 Each ( I have a driver's side and a passenger's side.)
    Valve Cover Driver's Side: $50 (SOLD)
    Exhaust Manifolds: $25 Each ( I have Drivers and Passengers sides)
    Oil Filter Housing w/ OPSU: $25
    Fuel Rails: $50
    Fuel Injectors: $20 Each ( Will sell individually or as a set of 8. If buying as a set then take off $30 from the total.)
    Ignition Coil: $5 Each (I have 6 left in total. It's not a bad idea to keep a few of these around for spares just in case.)
    Knock Sensors: $10 Each (I have all 4 of these available so let me know which one you want and I will get it to you.)
    Wiring Harness & Pigtail Connectors: The harness is no longer good since it was cut at the ECU by the previous owner, but does have lots of good pigtail connectors on it for coils, injectors, sensors, etc. If you need one of these just let me know and I will snip it off of the harness for you with as long of wire leads as I can reasonably get. $5 each is cool, if you want a few I will throw some extras in or something. Just trying to get rid of this.
    I do have many other random parts from the engine including other sensors, hoses, timing chain covers and bolts, so if you are buying something else and need another "throw in item" just let me know and if I have it then I will toss it in the box.
    All prices are negotiable.
    List Date: 5/22/2016
    For more info, click here to view the original listing: FS: Cam Adjusters, Actuators, Fuel Rails, Fuel Injectors, Knock Sensors, Ignition Coils, Etc...
    This item is no longer available.
    Apr 19 2013
    Fox Lake, IL
    bump
    -Robert-
    2009 Pontiac G8 GT 6.6-"Hairdryers"
    2005 Audi S4 4.2-"Au Naturale"
    2003 Explorer XLT 4.6-"Screwed"
