    Sep 03 2014
    2014 Audi Q7 Premium Plus, 2014 Audi A4 2.0T Quattro S-Line
    Ellicott City, MD
    Fault codes P1158 and P0068; '05 Audi A6 3.2 Quattro
    I ran VCDS on my '05 Audi A6 3.2 Quattro due to a CEL and got error codes P1158 and P0068 as shown below:
    Sunday,15,May,2016,10:33:28:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
    53 55 56 61 62 67 72 76 77
    VIN: WAUDG74F85N098366 Mileage: 141490km/87917miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    0F-Digital Radio -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
    Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
    Component: 3.2l V6 FSI 0020
    Revision: --H15--- Serial number:
    Coding: 0000000000000000
    Shop #: WSC 25015 444 90125
    VCID: 2B5F19758A1E111
    2 Faults Found:
    004440 - Manifold Pressure Sensor (G71)
    P1158 - 007 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 62
    Reset counter: 38
    Mileage: 138652 km
    Time Indication: 0
    Date: 2016.01.10
    Time: 07:16:13
    Freeze Frame:
    RPM: 1312 /min
    Mass Air / Rev.: 98.1 mg/str
    Temperature: 87.0°C
    Idle
    Voltage: 13.67 V
    Speed: 39.0 km/h
    000104 - MAP/MAF <-> Throttle Position Correlation
    P0068 - 007 - - Intermittent
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 62
    Reset counter: 40
    Mileage: 138652 km
    Time Indication: 0
    Date: 2016.01.10
    Time: 07:16:13
    Freeze Frame:
    RPM: 1280 /min
    Temperature: 87.0°C
    Idle
    Voltage: 13.67 V
    Bin. Bits: 00000010
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F1 910 156 H HW: 09L 927 156
    Component: AG6 09L 3.2 FSI USA 0020
    Revision: --H01--- Serial number: 0094042
    Coding: 0000002
    Shop #: WSC 02327 785 00200
    VCID: 2953E37D80E2031
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
    Component: ESP 8.0 quattro H03 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020895
    VCID: 2D5B176DB40A1F1
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H30 0180
    Revision: 30070501 Serial number: 10600300116079
    Coding: 0000015
    Shop #: WSC 09108 444 183291
    VCID: E3CF3155224E191
    Part No: 4F0 910 131 L
    Component: FBSAUDIC6 EZS H43 0070
    Part No: 4F0 910 335
    Component: FBSAUDIC6 KSG H26 0080
    Part No: 4F0 910 220 G
    Component: FBSAUDIC6 IDG H01 0053
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 732 Q HW: 4E0 035 729
    Component: Interfacebox H43 4610
    Revision: 00000000 Serial number: 360BB057519010
    Coding: 0000003
    Shop #: WSC 02335 785 00200
    VCID: 31630B1DA8327B1
    Part No: 4F0 910 609 B
    Component: Bedienteil MMIC6H07 0010
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F1 820 043 J
    Component: KLIMABETAETIGUNGH11 0150
    Revision: 00000025 Serial number: 00000000109556
    Coding: 0532518
    VCID: DBBF09B51A3E211
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 HW: 4F0 907 279
    Component: ILM Fahrer H14 0080
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013123
    VCID: E6C92841D17C6C9
    Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H05 0150
    Coding: 00062736
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0050
    Coding: 00141886
    Shop #: WSC 02335
    Address 0E: Media Player 1
    Cannot be reached
    Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
    Part No SW: 4E0 910 593 D HW: 4E0 035 593
    Component: SDAR SIRIUS H04 0670
    Revision: 00000000 Serial number: AUZ4Z7E3008150
    Shop #: WSC 00000 000 00000
    VCID: 2855E6799BE83A9
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 171
    Mileage: 138037 km
    Time Indication: 0
    Date: 2015.12.29
    Time: 16:34:23
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
    Component: 56 AIRBAG AUDI8RH29 0310
    Revision: 10H29000 Serial number: 00359D087FW6
    Coding: 0013622
    Shop #: WSC 25166 444 59267
    VCID: 2649E84191FC2C9
    Part No: 4F0 910 339
    Component: BF-Gewichtsens. 002 0040
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H07 0230
    Revision: 00H07000 Serial number: 90025050220048
    Coding: 0002041
    Shop #: WSC 02323 785 00200
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H06 0080
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
    Component: KOMBIINSTR. M73 H10 0660
    Revision: 00200000 Serial number: 4R8102225
    Coding: 2113263
    Shop #: WSC 09108 444 68671
    VCID: 1E39C0A1C9ACF49
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 080080520100FD
    Coding: ECFE73CC1B7904
    Shop #: WSC 02325 785 00200
    VCID: 2757E54596F6351
    Address 36: Seat Mem. Drvr Labels: None
    Part No SW: 4F0 910 760 HW: 4F0 959 760
    Component: Sitzmemory FS H04 0050
    Revision: 00000000 Serial number: 00000000896400
    Coding: 0082954
    VCID: E1C33B5D38520B1
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
    Component: MNS US H44 1100
    Revision: 00000000 Serial number: 378B$057515996
    VCID: 387536394B48AA9
    3 Faults Found:
    02261 - Data Medium
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 7
    Reset counter: 179
    Mileage: 136303 km
    Time Indication: 0
    Date: 2015.10.10
    Time: 15:43:15
    Freeze Frame:
    Hex Value: 0x5738
    Hex Value: 0x35D5
    Hex Value: 0x0B00
    Hex Value: 0x1280
    03183 - Data Media not Compatible
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 19
    Reset counter: 146
    Mileage: 140621 km
    Time Indication: 0
    Date: 2016.04.15
    Time: 13:05:28
    Freeze Frame:
    Hex Value: 0x571F
    Hex Value: 0x4E9B
    Hex Value: 0x0000
    Hex Value: 0x9494
    02927 - DVD Read Error
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 30
    Reset counter: 173
    Mileage: 140621 km
    Time Indication: 0
    Date: 2016.04.15
    Time: 13:04:52
    Freeze Frame:
    Hex Value: 0x5730
    Hex Value: 0xFCC8
    Hex Value: 0x0401
    Hex Value: 0x0000
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
    Component: TSG FA H11 0040
    Revision: 00000000 Serial number: D
    Coding: 0051947
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
    Component: Komfortgeraet H15 0100
    Revision: 01000015 Serial number: 01002598420000
    Coding: 0425021
    VCID: 2C5D1A698F10169
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Address 47: Sound System Labels: None
    Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
    Component: DSP-High C6 H14 0330
    Revision: PROD_01 Serial number: 00000000022679
    Coding: 0000026
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H09 0050
    Revision: Serial number: 00000000062796
    Coding: 0001114
    VCID: DEB900A1092C349
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
    Component: TSG BF H11 0040
    Revision: 00000000 Serial number: 0!D
    Coding: 0051947
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801
    Component: EPB CDEC0080 H03 0080
    Revision: --H03---
    Coding: 0005022
    VCID: 2045FE59F3D8C29
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000016
    Part No: 4F0 941 329 A
    Component: AFS-Modul links H05 0010
    Component: AFS-Modul rechtsH05 0010
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 394BY057514895
    Coding: 0000002
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H12 0490
    Revision: 00000000 Serial number: 00000000011925
    VCID: 234FF155E2CED91
    Subsystem 1 - Part No: 4F0 915 105 C
    Component: von VA0 2502020798
    Coding: 344630393135313035432056413032353032303230373938
    Shop #: WSC 00000 384 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 HW: 4F0 959 795
    Component: TSG HL H09 0010
    Coding: 0051754
    VCID: E9D3237DC062431
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
    Component: SDS 3501 US H45 0630
    Revision: 00000000 Serial number: 00000502020279
    Shop #: WSC 12336 024 394758
    VCID: 346D020957204E9
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 HW: 4F0 959 794
    Component: TSG HR H09 0010
    Coding: 0051754
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 HW: 4F0 919 283
    Component: Parkhilfe 4-Kan H09 0030
    Revision: --.--.-- Serial number: 11720502601505
    Coding: 0001206
    Shop #: WSC 131071 1023 2097151
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4F0 910 336 H HW: 4E0 862 335
    Component: Handyvorb2 H10 1130
    Revision: 00000000 Serial number: 00000007514755
    Coding: 0010900
    End ---------------------------------------------------------------------
    Sorry for the lengthy entry but I can't post attachments for some reason. I replaced the MAP sensor a while back due to the same error, but it didn't change anything. What should I be looking for?
    Sep 03 2014
    Ellicott City, MD
    Since nobody seems to know the answer to my question (or just isn't offering a response), here's what I've done to correct the problem. I cleaned the throttle body and attempted to perform a throttle body alignment. I made sure the battery voltage was above 11.5 volts (it showed 11.93V on the measured data screen) and then attempted to perform the alignment. I got an error and was unable to perform the alignment. The car is running fine and does not idle rough. The VCDS readout showed that the error signals were intermittent so my next step is to clean the connectors on the throttle body harness. I cleared out the codes before attempting the TBA. I took the car on a long trip to Pittsburgh from Baltimore over the weekend and never got a CEL during the entire trip so I'm hoping that cleaning the throttle body fixed the problem.
    Sep 03 2014
    Ellicott City, MD
    Drove the car to Pittsburgh and back over the holiday weekend. The wife has been driving it since we got back home and the CEL has not returned.
    Junior Member Two Rings
    May 08 2015
    Houston, Tx
    I just got the same faults the other day while doing a routine VCDS scan. I did not had any warning on dash. Beside those intermittent faults I got P1577 right mount engine solenoid valve (N145) which probably might be related or not. I clean up the throttle and intake manifold last year. True I use cheap 87 gas and I do not know how much deposit I would get. I follow your same post on other site and nobody seems to gave you any input. Now is not the right time to do maintenance on it but I will post back in future if cleaning solve the problem. Can't remember if I did a TBA and I have to look to find instructions for it. Anyway, appreciate that you came back with what you did to get those codes away.
    Doc
    And if I could ask how, check twice, do it once and use it forever...
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    thanks for making the post captain_video, i am seeing the same codes on my a6 i just bought, but i also had no CEL for them so i am going to attempt what you did first by cleaning the throttle body and doing alignment. here is the link to anyone else coming across it with vagcom:
    https://www.youtube.com/watch?v=FVEz7it48s8
    2007 A6 Avant 3.2L Black/Black, 265k miles
