Results 1 to 38 of 38
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Help with JHM Browser, can you access the server through the JHM browser or IE?
    I am trying to access the JHM server via their browser. Everything is installed but the browser application seems to be unable to communicate with the server producing Error 118. I can't find any firewalls on my end but can anyone that has JHM server access, try and see if they can log in or at least connect to the login screen. That way I figure out if it is on my end or just that the servers are down for the time being.
    Thanks in advance!
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Veteran Member Three Rings ktish's Avatar
    Nov 05 2012
    Is your VPN connected before trying to access the JHM server?
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Use their application and do not use internet explorer or any other browser to access the JHM browser.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jun 04 2011
    Clayton, CA
    Quote Originally Posted by ktish View Post
    Yes, VPN seems to connect without issue except it reads "APR secure VPN" and not JHM .... like the instructions indicate, but the VPN server is the vpn.jhmmotorsports.com address so I figure that is not an issue
    When attempting to load the JHM Browser 2.0, I get "Error -118 when loading url http://10.0.0.38:8080/"
    Build Thread
    Jun 04 2011
    Clayton, CA
    Can you guys connect to with their browser to the login prompt? That is where I am stuck
    Build Thread
    Jan 23 2013
    Chicago
    The part where it says apr secure vpn is normal as jhm uses aprs flashing system.
    I recall i had an error last time i tried to connect but that was at the vpn client, not this browser error youre getting.
    Jan 23 2013
    Chicago
    Perhaps the servers are down, or your computer is blocking access to port 8080.
    Jun 04 2011
    Clayton, CA
    Quote Originally Posted by Denio24 View Post
    That is my thought, hoping someone is available at home to check to see if they can access the server login and ruling out the server down possibility and ruling in my computer as the culprit
    Build Thread
    Jan 23 2013
    Chicago
    Ill check this for you right now.
    Jan 23 2013
    Chicago
    Ok. Figured out the culprit. Im getting the same error as you. Looks like the vpn cant connect, therefore. Cant connect to the server through the jhm browser. Looks like the vpn server is down.
    Any input Jake@JHM?
    Connecting to vpn.jhmotorsports.com through the vpn client failed.
    Jun 04 2011
    Clayton, CA
    Build Thread
    Jun 04 2011
    Clayton, CA
    Any input Jake@JHM?
    Thanks, at least I know that it is most likely on the JHM side right now and not just me. Last login for Jake was Friday night so I am pretty sure off for weekend. At least now I can hang this up until tomorrow when I can trouble shoot with them once they are open. If it was just me, I would be sitting here and driving myself nuts on why I won't work.
    Thanks for verifying. Although the funny part is the VPN client seems to be connecting fine. Unfortunately I am just computer savvy enough to fix some things, but networking issues are mostly over my head.
    Build Thread
    Jan 23 2013
    Chicago
    Weird. The vpn client isnt connecting for me, although all ports are allowed through firewall and forwarded. I was able to do it a couple months ago. I didnt change anything, now I'm unable to connect
    Jun 04 2011
    Clayton, CA
    I just disconnected, my assigned port was 2000. Do you think there is only one computer allows access at a time to that port? I am at the limit of my port address knowledge, sorry if this is a silly statement.
    Build Thread
    Jan 23 2013
    Chicago
    Quote Originally Posted by rongeur View Post
    Not that i know of, no.
    Jun 04 2011
    Clayton, CA
    Alright, til tomorrow it waits. Hopefully I can get it sorted easily.
    Build Thread
    Jun 04 2011
    Clayton, CA
    Follow up, turned out to be my home internet connection was not allowing the VPN client communicate despite appearing to be logged on initially
    Build Thread
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    For future reference- If you get error 118 on the JHM Browser, that means you are NOT logged into the VPN prior to opening the JHM Tuning Browser OR you are not able to connect your your VPN through the JHM Browser because of IP Configuration.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Hey jake, pretty sure I spoke with you earlier actually because I am stupid and was reading the wrong password.. anyway it says to connect the car to a 40a charger. I am assuming it has to be a 40a constant and not a 40a+ engine start charger correct? I just want to make sure because if so I need to buy one because mine is only 10a constant and 50a start.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Established Member Two Rings pvltr_Chuck's Avatar
    May 05 2014
    Cedar Falls, Iowa
    Quote Originally Posted by yeoj112689 View Post
    I just flashed my car over the weekend and I picked up this charger http://www.farmandfleet.com/products...e-starter.html. It was 100a start, 15a fast charge and a 2a slow charge. So, I just flicked it to the 15a fast charge and had no issues
    Daily - 08 Audi A4 6MT - Stage 2 JHM 91 octane - JHM short shifter - JHM test pipe - TT catback exhaust - ECS boost gauge - ECS snub mount
    Sold -- 06 Acura RSX-S 6MT
    Aug 31 2011
    Lathrop
    All you need to do is keep the battery voltage above 12v or else you run the risk of bricking your ECU.
    Veteran Member Four Rings RoguesGambit's Avatar
    Dec 19 2012
    Eatontown, NJ
    Getting that problem as well, and all this internet stuff is Spanish to me
    Lemme double check all this before I attempt it again
    JHM St2 w/HPFP, JHM HFC+B7 S4 FI Catback, JHM St1 Clutch/Flywheel, S4 Recaros, JHM Shift-Trio+Cross Rod, Bi-xenon Headlights, JOM Smoked Tail Lights, Enkei PF01, Conti DWS, Solo-werks S1 Coilovers
    More to come
    Also, my story: https://www.amazon.com/Sage-Mike-Fra...7646774&sr=1-1
    Jun 04 2011
    Clayton, CA
    I dont remember exactly but I had to reset my router IP address to 192.168.1.1 which is a default address. Comcast / Xfinity sometimes uses 10.1.10.1 which was preventing me from connecting to the JHM VPN.
    Build Thread
    Oct 24 2015
    Perth, WA
    One is a IP address (local) and the other is a subnet.
    My respray thread
    Established Member Two Rings shamp's Avatar
    Oct 18 2014
    Montreal, QC
    I was getting the error 118 issue as well 2 days ago but that was because I was opening their browser before having the VPN connected.
    Sent from my LG-H831 using Audizine mobile app
    '08 A4 Avant 6Spd
    @thatcanadianwagon
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    I had trouble getting it all to work awhile ago when I tested it (I haven't installed it)
    I solved it by using my Mac instead of my windows computer
    I tried everything on that windows, I reformatted windows 10 three times installed 64 bit twice, lost everything I had on my external hard drive it went on and on, I tried for two fcking days
    I went to my Mac, first time I tried it it went right in I hate windows
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Dec 19 2012
    Eatontown, NJ
    Shoulda got a Mac
    This computer stuff makes me feel retarded
    More to come
    Aug 31 2011
    Lathrop
    typically err 118 means you are not connected to the VPN before trying to open the browser.
    People also do not setup the VPN profile before trying to connect to the VPN.
    I HIGHLY suggest people read the instructions provided int he windows folder that matches the windows software on your PC. It explains every step for setup. There is also a troubleshooting document for common issues.
    Jul 25 2016
    new hampshire
    Quote Originally Posted by RoguesGambit View Post
    Shoulda got a Mac
    Yes
    Don't feel too bad, computers are a pain unless you really spend some time on them
    Quote Originally Posted by Jake@JHM View Post
    Idk if you remember Jake but I had contacted you and started a thread with some mega detailed posts and screenshots and at the end of it the only answer that I/we concluded on was the fact that I was running windows 10 on a 6/7 y/o laptop and that windows was not correctly communicating with the hardware and the drivers weren't working properly etc
    I did everything the instructions said and more and it wouldn't work, I turned on my Mac, went into boot camped windows and it worked first try and all I did was type in the information.
    So I will say that it does not matter how well you follow the instructions or what you do, sometimes the programs will simply not run no matter what
    Eric
    Aug 31 2011
    Lathrop
    Quote Originally Posted by pezgoon View Post
    Yes
    I understand that, which is why I said common issues. Your issue is a very rare one.
    We get a LOT of people having troubles because they are NOT reading the instructions and just trying to open the browser without installing/setting up anything.
    Jul 25 2016
    new hampshire
    Hahaha, I could definitely see that happening.
    I don't get why people are always so against reading directions, so many times I've had people need my help assembling something or other and all of their problems were because they didn't follow the directions haha
    Eric
    Aug 31 2011
    Lathrop
    I don't know either, and am also guilty of it.
    However, if I get to the point of getting stuck I will then go for the instructions.
    Jul 25 2016
    new hampshire
    Haha! You people!
    Anytime I get anything, even a car. The first thing I do is read the manual/instructions front to back
    Always have always will
    Eric
    Aug 31 2011
    Lathrop
    Haha! You people!
    I like puzzles so it's always fun to see how far I can go without them
    Dec 19 2012
    Eatontown, NJ
    Well, I'll give it a shot once I get home
    Also got the cable, so who knows, maybe I'll be st1 tonight
    More to come
    Jul 25 2016
    new hampshire
    Ya but it's not so fun when you've rammed the wrong bolt in the wrong hole and now you can't assemble it right
    Eric
    Oct 24 2015
    Perth, WA
    Thats what she said.
    My respray thread
    Jul 25 2016
    new hampshire
    Quote Originally Posted by Okedokey View Post
    Eric
