Page 166 of 166 FirstFirst ... 66116156164165166
Results 6,601 to 6,637 of 6637
  1. #6601
    Established Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Quote Originally Posted by evil35r View Post
    30-100 and 60-100. Beat my best by .2 30-100 and beat my 60-100 by .61 Iíd say thatís a improvement. More to come this weekend.
    [IMG] [/IMG]
    Damn. I need a big crank pulley :3
    187/57 - e85 custom tune (EPL) - custom exhaust -
    ported blower - IABED TB - Brembo BBK - APR CPS - USP intake- 034 sways and drivetrain inserts - cr-15 - 034 density control arms - Koni sport shocks - Eibach lowering springs - VMR v804 -PSS - N2O coming 😎
  2. #6602
    Senior Member Four Rings evil35r's Avatar
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Yea that 60-100 is the fastest any B8 has done besides Oleg
    13 S4: EPL, CTS 57/XLR8 196.5 Meth/E file, ROC-EURO w/ velocity stack, RSE test pipes and custom catback, ECS inserts, 034 subframe mounts, CR-15, H&R Sports, ECS Slotted rotors, Akebono pads, Snow Performance meth dual 375 nozzles, 034 rear sway, coolant pump mod/divorced, Merc hx, AG M590 wheels/Indy 500ís, iABED 75mm TB, Autotech, Matty Blower with hygroscopic vents.
    11.27 @ 122 via Dragy W/ 180/57
    Soon: ECS Catch can install, Brisk DR10S
  3. #6603
    May 08 2018
    Berkeley, CA
    Lol those cars are on another level. I wouldn't even bother comparing us to them.
  4. #6604
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Never will I itís a Turbo completely different level haha. All I want is the blower record and Iím happy which Iím pretty sure weíll have soon. Drag radials have been ordered
  5. #6605
    May 12 2008
    I'm sure its been answsered, but I couldn't find it. Is there any interest/potential for a fuel cut launch control?
  6. #6606
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    The fact that I canít even hookup at 2500 rpm launch at all on street tires now itís not worth it. But would it be cool yea...
  7. #6607
    May 12 2008
    You're a bit of a one-off lol.
  8. #6608
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Lol true
  9. #6609
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    that and we can't even do real burnouts at the strip...kind worse off then RWD cars now. and that was the best part of a dig our killer launches
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake
    AMS Alpha Cooler, EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, PS4S | Bilstein PSS10's | AWE Touring /Res DPs
  10. #6610
    Feb 17 2017
    Tempe, Arizona
    Good deal on the Tunes Chris...and I'd get to use the 75mm TB and 4" intake I already have. I'll let you know after I put about 400 more miles on car to ensure still evap, pcv code free. I really want to put that iABED TB back on my car...big difference in response and acceleration.
    If any of you have time...is this about what's to be expected with my logs? They sure looked a lot better with 75mm and Brsik at .024 & .025
    Couple of logs with the 75mm TB, Ported SC, 4" intake, Sunoco 100
    Brisk Silver Racing DR12YS cyl's 3,4,6 gap to .024, rest at .025
    https://drive.google.com/file/d/1fda...ew?usp=sharing
    https://drive.google.com/file/d/1yuL...ew?usp=sharing
    Logs with stock tb back on, ported sc, cts intake, Sunoco 100
    NGK 2668 BKR8EIX IX Iridium Plug (that my shop took liberty to gap at .028 when I said .024)
    said Andrew at GIAC told them to gap at .028 for DP...
    Now I'm getting timing pull/bypass opening and race is tonight and I don't have time to re-gap them..
    123456-028-gap-ngk-BKR8EIX-run2
    https://drive.google.com/file/d/1Ge_...ew?usp=sharing
    123456-028-gap-ngk-BKR8EIX-run3
    https://drive.google.com/file/d/19Cc...ew?usp=sharing
    gen-028-gap-ngk-BKR8EIX-run4
    https://drive.google.com/file/d/1gbq...ew?usp=sharing
  11. #6611
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Fwiw my brisk weíre running hot I switched to NGk 9ís same as the uc cars gapped to .024...
  12. #6612
    Feb 17 2017
    Tempe, Arizona
    yea they said mine looked pretty warn and were only in there about 9 months
  13. #6613
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Yea tbh if youíre running DP, TB and ported blower etc makes sense to go a step colder. Mine run fine got those dragy results with them so they work lol.
  14. #6614
    Feb 17 2017
    Tempe, Arizona
    You're talking about these right?
    NGK "one-step colder" BKR9IEX
  15. #6615
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Yeppers
    - - - Updated - - -
    You want 2-3 burn discoloration marks on the threads of your plugs any less to cold anymore too hot I had 5-6 lol
    - - - Updated - - -
    You can also look at the ground strap but I use meth not much to read.
  16. #6616
    Feb 17 2017
    Tempe, Arizona
    These are what mine looked like after 9 months. All the while on 100 oct or at least E27-E30. Plugs 3,4,6 gapped at .024 and the rest at .025
  17. #6617
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Yep hot goto 9ís trust me.
  18. #6618
    Mar 09 2018
    Pittsburgh
    What tune is this on? I don't see meth listed and that timing advance looks killer!
    13 S4 DSG
    EPL ECU+TCU tune, 183mm FLuidampr, EPL Supercharger Pulley, Jokerz ported blower, IABED 75mm TB, IE Intake, Merc HX, Autotech pump, Gutted stock cats , AWE resonated DP's and Track rear, 034 inserts+motor mounts, 034 RSB, 034 Springs, Stoptech Sport Pads&Rotors, VMR v706 + Firestone Indy 500
  19. #6619
    Feb 17 2017
    Tempe, Arizona
    Quote Originally Posted by nick0188 View Post
    if that's directed at me...giac race map 100oct. But I'm real unhappy with the drivability of the DSG tune on race map and the fact that I had to take TB and 4" intake back off because they haven't revised their file for the codes a lot of people are getting with larger TB when other tuners did so in a day or two. And I've never had a log where the rpm went to even 7000 and it's supposed to be at 7200. And they don't personalize files for meth etc, just 2 files pump and race.
    So that's my interest in looking into switching tuners
    I'm bleeding more boost with the stock tb back on the car...and I miss the response time for acceleration of the 75mm TB, need to get that puppy back on there quick :)
  20. #6620
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Switch over to the dark side lol
  21. #6621
    Veteran Member Three Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Why canít I see any of the pics you post? They are broken images....
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 1
  22. #6622
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Whitee View Post
  23. #6623
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Only for you man nobody else lol
  24. #6624
    Senior Member Four Rings maty360414's Avatar
    Oct 13 2015
    Dallas,TX
    Quote Originally Posted by vpls4 View Post
    Switch over you will be happy here.
    Sent from my Pixel 3 XL using Tapatalk
    '13 S4 | EPL DP W/M | EPL TCU | AEM W/M | Tampa Ported S/C | iABED TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | Vertini RF 1.3 | Michelin PS4S | Sport Diff | Akebono Pads | 1Res 1NonRes X-Pipe | RS Grill | Spoiler/Diffuser | RS4 Bumper | J-Code | 11.19@121.3 MPH
  25. #6625
    Senior Member Two Rings Tom Sawyer's Avatar
    Apr 01 2007
    TN
    Quote Originally Posted by k186 View Post
    Great to hear, Tony! And thanks for the reassurances.
    The tune runs great and the car feels incredible. Just a minor OCD annoyance seeing that code haha!
    Just ran my first monthly scan since my Stage 1+DSG tune and throwing the engine speed exceeded as well. Glad to hear it's nothing to worry about but will be happy to see it sorted eventually for same OCD reasons!
    Tune is fantastic, can't imagine the car without it now. Car runs smoother (plugs probably helped as well), and under spirited driving is really awake now. DSG tune is interesting... was hoping some of the stop/go traffic lurching in 1st might be reduced but still does it from time to time. Shifts are definitely faster in Dynamic/S under hard throttle, not much change at all that I can tell in D. One thing I was curious of from others with the DSG tune, I find that in S it will still sometimes shift early if you have just tipped into the throttle after an earlier shift? For example, shift from 2->3, push maybe 1/4 more throttle, and it will not run the RPMS up, shifts at 2500-3000. Seems like if I'm not in it hard through the previous gear, the next point is already 'decided' regardless of more throttle. Probably user error.
    2016 S4 P+ DSG, Florett Silver Metallic, Panda Nappa Leather, Tech/B&O with tweaks/Side Assist, Sport Diff; Eurocode Intake, CR-15, EPL Stage 1 + DSG Tune
    Gone but not forgotten: 2000 B5 S4, 2004 B6 S4, 2003 RS6
  26. #6626
    Jan 17 2017
    For those of you running Water/Meth... Are you running the water/meth file? I plan to install water meth and I want to only run the water meth with a switch. Do I really need to have the file for water meth?
  27. #6627
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by GoTImeS4 View Post
    I was chatting with Chris recently, and it sounds like the answers is "yes" to get the full benefit. Reading elsewhere, you might be able to run some water/meth to lower IATs on a non water/meth tune. But if you are on the water/meth file and then you want to switch off the water/meth then you will want to switch to a non water/meth tune. I don't know how big of a benefit (I haven't seen the data) one might get from running water/meth w/o the water/meth tune (lower IATs are obviously good). You don't want to run the water/meth tune if you don't have water/meth.
    I ditched (back burnered) my plans to run water/meth until I see what summer really brings. Getting methanol in quantity and ensured quality at a reasonable price where I'm located hasn't shown to be the easiest thing to do.
    I think it is worth talking to Chris though about your plans/goals for guidance.
  28. #6628
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    No you donít have to have the file to run W\M wonít hurt anything you just wonít get all the rewards of having it. Higher timing etc.
  29. #6629
    Jan 17 2017
    Ok thatís what I figured. Iím probably going to get the water meth file and the dual pulley file and I can switch it on and off. Iíll be pretty much the same setup as evil except Iím running the 187mm crank pulley.
  30. #6630
    Nov 10 2017
    New York
    for those of you using the EPL logging tool.
    do you hit start, then start recording , then stop recording, then stop ?
  31. #6631
    Oct 13 2015
    Dallas,TX
    - - - Updated - - -
    Quote Originally Posted by JayTirbhaw View Post
    yes then send to EPL, then DONE
  32. #6632
    Jan 30 2015
    SC
    So we still can't save the log to our own pc?
    Sent from my SM-G920V using Tapatalk
  33. #6633
    Oct 13 2015
    Dallas,TX
    Quote Originally Posted by Johnson View Post
    No
  34. #6634
    Mar 22 2016
    73 Jimmy 496 BBC
    VA Beach
    Theyíre in a hidden folder called data logging sessions, theyíre encrypted but if you ask tony or Chris for a template that you can see they will do it eventually. More to come with it be patient.
  35. #6635
    Stage 2 Banner Advertiser Four Rings Chris@EPL's Avatar
    Jun 23 2011
    Working on finishing all of the North American Stage 1 and Stage 2 files for the Q7 from 2010-2015, but most are ready to go. Shoot us a PM or email if you are interested.
    European Performance Labs
    http://www.facebook.com/EPLabs
    https://www.instagram.com/eplabs/
    (203-345-6499)
    Chris@eplabs.net
    Please feel free to contact us with any questions!!
  36. #6636
    Oct 13 2015
    Dallas,TX
    I have iABED TB and 4" intake back on car and ready for performance gap. Currently at .028 from diagnosing other issues.
    about gapping plugs... i know if i saw activity on the IGA_AD_1_KNK[x] logs it was usually too much of a gap considering fuel was good.
    I'm thinking of going .024 on BKR8EIX
    What are the symptoms of too narrow a gap?
    You jumped ship to EPL?
  37. #6637
    Feb 17 2017
    Tempe, Arizona
    whoops disregard moved ? to beyond stage II...
    not sure yet... the price point and being active on here is awesome though. If I change it will be EPL.
    I am getting the P2279 & P0068 codes because giac, and I know everything is right with the install, they've taken it off and on now 4 times and always has those two.
    My other codes resolved so I know it's tune related. So far hasn't caused any issues. Still testing drivability of their tcu tune with the ported sc and 75mm tb.
