Page 1 of 205 1231151101 ... LastLast
Results 1 to 40 of 8189
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    EPL B8/B8.5 Owners Discussion Thread
    New thread for us to ask questions and share info now that the other thread is development updates only.
    So yesterday I had my pulley installed, flashed to Stage 2, and wow.
    Big butt dyno difference.
    Pic for clicks
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    A local guy had the chance to compare Revo with EPL and said how much more torque EPL has down low.
    Apr 27 2011
    MD
    Quote Originally Posted by GRUMPY-S4 View Post
    I was told that Stage 2 is a torque monster with EPL, so far I'd have to agree.
    I have about a 25 min drive to jujitsu in a bit, I'll be pushing it to help adaptation lol
    IG: @s4dad
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Our plan was to rename the current thread and start a new development only thread. The current thread has 40+ pages of info. If it's ok, I'd ask that this thread be closed and let us make our changes next week! Thanks!
    Signing off for the weekend ! Talk to you guys Monday!
    Apr 27 2011
    MD
    Cool, when you make the changes then delete this one.
    IG: @s4dad
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Its interesting Ive never seen a Revo car get a decent 60ft and I think its because they just dont develop enough low end torque with their tuning method... anyway heres what im trying to work out with my EPL tune currently:
    We recently did some logging on my EPL stg2 tune and saw that the car was not bleeding boost but it was being conservative on the timing. I'm going to get with Tony on Monday and see if he can add 5-6 degrees of timing to get my car running a little better
    Comparing tunes, the EPL tune makes much more low/mid range torque than my Revo tune. But overall the car is a tad slower because it's not making as much power at high rpm. Hopefully adjusting the timing values will correct my issue and for reference my Revo tune went 12.6@112 with a crappy 60' and 93 octane.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Nov 16 2015
    DFW
    From a Roll timing is pulled when shifting through gears. Max is like 15 degrees! Not sure if thats the case with all tunes though. Would be cool to see if APR does the same
    Established Member Two Rings DKo5's Avatar
    Aug 25 2014
    Hey Tony, I hate to clutter a thread but could you check your PMs? I haven't been able to flash after getting pulleys installed. Thanks!
    Sent from my Nexus 5X using Tapatalk
    '18 TT-RS Unitronic Stage 2 E85
    '18 A4 Stock
    '17 Q7 APR Stage 1 91
    Jul 05 2014
    Houston
    We were seeing a max of 17 degrees on mine. Thats with it being adapted on an E85 blend. In comparison an apr car logged 22 degrees of timing with no bypass.
    Nov 16 2015
    DFW
    Quote Originally Posted by fitzydude View Post
    On the 93 tune thats about what I was seeing I believe. On the E85 I think I get like 20. Still room to have more.
    Apr 27 2011
    MD
    Tony said he will have an update for Stage two this week.
    IG: @s4dad
    Nov 16 2015
    DFW
    Quote Originally Posted by bmoreS4 View Post
    Stage 2 93 or E85?
    Apr 27 2011
    MD
    I'm 93
    IG: @s4dad
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Question for the Stage 2 E85 guys... Do any of you notice a audible difference in injector noise (ticking) on cold starts?
    2016 S6
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    Any more details on this?
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    May 11 2014
    United States
    Quote Originally Posted by importraceram View Post
    +1 and where are those increased launch control RPM changes. Havent heard anything in a long time and I feel that is an easy change and one that can net some good 60' times.
    Apr 27 2011
    MD
    Seems to me my Stage 2 has gotten stronger over a few day span.
    Flashed Sat, everyday it feels a little better, now its feels very strong. I'm also driving hard during adaptation time.
    IG: @s4dad
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    the higher the "effective" octane of your fuel, the more timing you can run. the reason why timing starts getting pulled when the car is running hot is to prevent premature detonation from occurring. basically, your ecu wants detonation to happen at the time the spark is ignited and no sooner. but with a combo of high IATs, low octane, and increased boost pressure, detonation may occur spontaneously and prematurely.
    so all that being said, comparing max timing without additional info about octane, boost, cooling/running conditions doesn't quite paint a complete picture. personally, i would give up a few degrees of timing if it means i'm much less likely to knock. while running more timing generally indicates more power, it's a delicate balance of different factors.
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Apr 27 2011
    MD
    Quote Originally Posted by jomama229 View Post
    the higher the effective" octane of your fuel, the more timing you can run. the reason why timing starts getting pulled when the car is running hot is to prevent premature detonation from occurring. basically, your ecu wants detonation to happen at the time the spark is ignited and no sooner. but with a combo of high IATs, low octane, and increased boost pressure, detonation may occur spontaneously and prematurely.
    /truth
    IG: @s4dad
    Jan 26 2015
    2017 XC90, a workbench
    CO
    What is the difference in peak boost between single vs dual pulley?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Apr 27 2011
    MD
    Quote Originally Posted by Hofahome View Post
    I'd like to know as well.
    Also, stage 1 to stage 2 is 11psi to 15psi, correct?
    IG: @s4dad
    Feb 20 2012
    e90 M3
    NH
    Had a chance to test out the launch now that I am officially have the stage 2 file on the car. A couple things jump out to me. First I was quite surprised that I didn't get a chirp or anything audible from the tires. They have just over 2k on them so they are quite new but this was on an unprepped street rd (just over the boarded in Mexico of course). The second thing, as seen in this video, is clearly the car is shifting early as I have read about from several other members posts with some EPL DSG tunes. I'm currently on the 4/28 DSG flash.
    Wondering how this compares to others who have launched their EPL stage 2's and other companies. Obviously this is just a video so any number/times would just be rough speculation and irrelevant. Does something look off?
    Apr 14 2016
    Austin Texas
    Needs adaptation time.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Apr 14 2016
    Austin Texas
    And, there is a 4/28 dsg update?
    Feb 20 2012
    e90 M3
    NH
    Quote Originally Posted by chet.rowles View Post
    Have had the tune for around a week. Everything is adapted. Looking for potential stage 2 updates this coming week.
    Senior Member Three Rings kpykng1's Avatar
    Feb 17 2016
    Ventura, CA
    New to the whole EPL tune flashing, so if I wanna go back to stock I just use the program and select the stock flashes and go. It doesn't cost more credits or anything to go back and forth?
    2014 SQ5 Glacier White - 22" Touren TF01 - AWE Touring w/resonated downpipes - KW SC Coilovers - 034 Motorsports Rear Swaybar w/ endlinks, RSNAV System
    2017 MINI Cooper Countryman S
    Mar 21 2015
    Quote Originally Posted by kpykng1 View Post
    That's all you have to do. No extra fees.
    Feb 17 2016
    Ventura, CA
    But you have to use the same computer cause the EPL flash program is locked by the serial number to that program on that computer? Or just contact Chris or Tony if I install the program on a different computer.
    I only ask cause I had to do it from a work laptop cause the flash program wouldn't work on my personal computer.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    If you change computers you'll have to contact EPL to change serial numbers.
    Mar 31 2015
    Auburn Hills, MI
    Really dumb question but where do you buy the EPL tune?
    Website is under construction and found 1 company selling it but no details, just EPL Tune and a price.
    Looking for Stage II, pulley, and DSG tune.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Eric_C View Post
    their facebook is pretty active https://www.facebook.com/EPLabs/
    or you can PM tony or chris
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Deactivated Four Rings
    Jun 23 2011
    PM sent
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Well, I think that the stage 1 reflash has definitely given my car some extra powers. I smoked a C5 Corvette in Mexico this morning. I was behind him and he punched it. I followed suit and by the time I hit 4th I walked him like he was standing still.
    Not astounding by any means, but for a car that has 350 hp and is about 650 lbs lighter, I think I did pretty well considering it was from a roll :D Can't wait to go stage 2 in a few weeks!
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Quote Originally Posted by jsh139 View Post
    You can beat a C5 base vette when your car was stock. My cousin has one and I had him at the drag strip by around .4 second when I was stock.
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by B8 S4 View Post
    Damn
    Senior Member Two Rings sittinlow's Avatar
    Apr 08 2009
    Long Island
    Not sure if this is the right place to ask, but looking for some advice. Trying to Flash and flash loader is blank. Any suggestions? Figured someone may have ran into this and know a quick fix. I already sent serial to EPL and it updated earlier.
    Established Member Two Rings ZChicagoS4's Avatar
    Nov 02 2013
    Chicago
    Damn
    Don't be upset You'd beat the E/T but he'd have a higher trap.
    2015 Audi S7 Prestige. Bang & Olufsen, Black Optics, Night Vision, Driver Assistance, Adaptive, Alcantara Headliner, Pre Sense, Lane Assist, Cold Weather, etc.
    2017 Jeep SRT. Borla ATAK.
    2017 Wrangler Unlimited Hard Rock
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Quote Originally Posted by sittinlow View Post
    I actually Am experiencing this same issue so that makes me feel Better.
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by ZChicagoS4 View Post
    This makes sense then why I was able to take him from a roll. Stock-for-stock, he would have had me, but now that I am Stage 1, it's a different story. Just feels good to know that it isn't all snake oil!
