Originally Posted by
jacobsen
Well I put my finger over it while the car is running before and it's sucking air. So it's some kind of vacuum leak one way or the other.
The wastegate actuator port on the opposite side from the normal port, must be OPEN, not connected to anything or capped.
There is something wrong with the vacuum system plumbing if there is vacuum at the opposite side actuator port. For this to occur, the control pressure hose from the N75 must be at vacuum pressure with the engine idling, and the diaphragm must be split so that the vacuum pressure can be applied to the other side of the actuator diaphragm. In order for there to be vacuum from the N75 to the actuator, the N75 control pressure source connection must be incorrectly connected to a vacuum pressure source instead of the compressor housing volute.
The N75 control signal source is incorrectly connected to a vacuum pressure source, and the diaphragm in the actuator is defective.
