Results 1 to 21 of 21
    Active Member One Ring gmadd's Avatar
    May 31 2014
    Montreal
    My B8 S4 Revo stage 1+ dyno results
    2011 S4 revo stage 1+ and their transmission tune
    [IMG][/IMG]
    2011 S4, DSG, Sport diff, Injen intake, Borla exhaust, Alu Kreuz, H&R rear sway bar.
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Can't see a picture
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    May 31 2014
    Montreal
    Jun 20 2015
    NC
    Looks about right for stage 2. Do you have an intake?
    May 31 2014
    Montreal
    Quote Originally Posted by Sceanzo View Post
    ya, have an Injen intake and Borla exhaust
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    great results, looks inline with other stage 2 files. What octane?
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    May 31 2014
    Montreal
    Quote Originally Posted by Loe View Post
    I'm on 94 octane
    Senior Member Two Rings Shaun Perry's Avatar
    Jan 02 2013
    San Ramon, CA
    I thought stage 1+ takes it into the 4's to the wheels
    May 31 2014
    Montreal
    Quote Originally Posted by Shaun Perry View Post
    Ya, I was hoping for the same...but still very happy with the results.
    Apparently they had a manual S4 with test pipes and put down 409 to the wheels...
    Senior Member Two Rings Seattle996's Avatar
    Apr 07 2009
    I've always been a fan of the REVO setup and I'm still contemplating it. How do you like it? Any thoughts or is it similar to all the other tunes out there?
    May 31 2014
    Montreal
    I can't compare it any other tunes but I love it ! From 3000rpm this thing now pulls like a train all the way to red line ! 😀
    Sent from my LG-H812 using Tapatalk
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by Seattle996 View Post
    REVO cars make nice #'s on the dyno but they're all slower than EPL/GIAC/APR on the street. They have a safe and reliable tune, just not as fast as the other tuners
    Nov 29 2013
    Silver Spring, MD
    Quote Originally Posted by mrmomo313 View Post
    The way they tune is different from GIAC and APR as well. Others more knowledgeable will be able to explain the difference.
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Typically Revo cars trap very well for the times that they run, that figures because they dyno so well, they're making the horsepower.
    But I've haven't seen Revo cars cutting great 60 foots like a 1.6-1.7. I just don't think Revo cars are developing the low end grunt they need to get moving. I also think their partial throttle tuning is conservative as well which is great if you're looking smooth/driveable power development, but bad for total performance.
    I think the perfect tune would use giac/apr's tuning method (no bleed/conservative timing) below 5500 rpm's and switch to Revo's tuning method (high timing/boost bleed) above 5500 rpm's. Resulting in the ultimate tune combining the best of both tuning methods.
    Having tried Revo I think it's a great tune for roll racing with an exceptional price.. I paid like 850 for the 1+ software and installed my own pulley. But I was looking for better performance at the track so I decided to move on.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Oct 27 2010
    Michigan
    Quote Originally Posted by ptper View Post
    In good conditions you'll see giac cars hitting ~2600 hPA and apr around 2300 without bypass.
    Specified is around 2100 hPA for revo, which depending on ambient pressure is around 16psi boost. The specified pressure in their tune is setup for average conditions. The guys who take their revo cars to the track at lower altitude/great conditions end up bypassing boost because of that
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Those numbers look strong. Do dynopacks read higher than mustangs?
    Jul 21 2004
    South Florida
    Quote Originally Posted by Thurston View Post
    Dynapaks are hub dynos and tend to read pretty high. You bolt the hubs directly to the machine (remove the wheels). Dynojets and Mustangs can read higher or lower than each other. Dyno Dynamics tend to read god awful low.
    Mike
    2018 Audi S5
    Gone-
    Apr 27 2015
    canada
    Quote Originally Posted by bhvrdr View Post
    Dynapaks are hub dynos and tent to read pretty high. You bolt the hubs directly to the machine (remove the wheels). Dynojets and Mustangs can read higher or lower than each other. Dyno Dynamics tend to read god awful low.
    Mike
    Thanks, i always enjoy ur contributions.
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Mike
    My local Dyno is Dyno Dynamics & is said to read low/accurately ..... so I took my reo stage 1+ to them
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    ^^^This^^^
    The rest of this thread? Take it for what it is. A single dyno won't tell you a whole lot other than maybe to confirm that something isn't seriously wrong. And I mean that as no offense to anyone. I've dynoed a bunch of S4's on the same dyno (I think 8-9 different cars now), and as cool as it is, it still doesn't mean a whole lot on it's own; although we at least have a couple baseline dynos. It's another data point just like a set of logs or drag strip times. If you want to really see how your car is running, run it at the drag strip and log it. That will tell you way more than a dyno ever will. Better yet, do all three, and you'll really understand what your car is doing....
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jul 21 2004
    South Florida
    Quote Originally Posted by xpoweruk View Post
    Right on. It looks like that operator did a parasitic loss test on that run...you can do them on some dynojets as well (the used to do this at champion racing on my A4). This is where they let the car spin the machine down. It feels like it takes forever. The car stays spinning down on the machine for probably a full minute or two. They calculate back to chp then. Check your wheel hp numbers from the tuner though and you'll see they are lower than most other dynos. The MAHA dyno is notorious for this. It'll spit out, say, a 240whp measurement and then on the calculations table will show 250hp in drivetrain loss and then say you made 490chp. It is what it is. All dynos are different like Jran is saying above. They're data points.
    Mike
    2018 Audi S5
    Gone-
