I have about 1700 miles on a new timing belt and the parts that go along with the service. Ordered the gates blue belt kit from ECS tuning. I have been noticing a rattling kind of sound once engine is warmed up.
Couple days ago I pulled the covers and saw the belt was moving a little side to side on the water pump pulley, in sync with the noise. The belt between the cams where it goes around the WP pulley is loose enough that I can get my hand in there and manually turn the pump. That has got to be too loose. Also looks like the backside of the belt, the blue is wearing a little down from slipping. Car runs fine and is not over heating at all. The belt opposite side of cams seems tight.
Could this be caused by maybe not properly pre tensioning the belt or is the new tensioner maybe shot? Even if pre tension was not done correctly, wouldn't the tensioner take care of that? I did everything to spec from the blau parts and happy wrenching DIYs. Only thing I could see messing up was the previous tension. I had got to the part where I was putting fan clutch back on and realized I had forgotten to put the metal plates back on the end of the heads...Duh. It was about 11PM and tired. I ripped every thing back down and reassembled up to the fan clutch before going back to bed. The pre tensioning is all I can think I may have messed up being so tired. Not even sure I did mess that up. Hence the question about the tensioner taking care of that.
Dreading it, but if I get some time today I am go to start digging into this. Would really like some thought or opinions on what to look for when doing this. Is it a case of locking cams and crankshaft at TDC and redoing pre tension, or will I be able to tell if tensioner is bad? Would hate to retension everything and find out is a bad tensioner and rip apart again. Really appreciate any input. Thanks guys.
