Originally Posted by
waxxonMTL
folks... pulled trigger on stage 2 93 octane.. 2013 CPO.. if I still want a chance to get warranty work done on my car, the logical choice would be to swap the S/C pulley right ? since an OD crank pulley will be detected as soon as the tech open the hood ?
is that a resonable logic or should i ''man up'' and go crank pulley anyways ? Not gonna lie.. i like to keep things as reliable as possible and i would prefer to see a dampered crank pulley than a solid piece of CNC ( no matter what JHM is telling us..). Then, if i play advocate, how can i be sure that fluidamper or even ATI damper has the right dampered frequencies ? lolll
I can see myself going dual pulley 93 tune after my cpo warranty is done ( in 16 months), but till then, think I will stay stage 2 for a while.
I think you answered your own question lol. Do the SC pulley then after CPO slap the OD one on. Or just man up
yjypm
If I get dual pulleys should I use the OEM belt or the belt comes with sc pulley?
My logic tells me OEM belt should be a better fit though.
Use the belt that JHM supplies
Dakkath
We need a damn poll for these pulley failures. From the recent topics I've read, most OEM pulley's are failing after xx miles with a aftermarket SC pulley, however some are failing w/o aftermarket SC pulley.
But have we had any pulley failures with the overdrive JHM pulley? Would be nice to get some data around this to make informative decisions when going stg2. I apologize if this has been done before, I'm sort of new to this sub forum.
I honestly doubt you will own the car long enough to have the JHM crank fail after the stock one fails... The stock crank is failing around 55-70k miles for those that have posted on here and AR. I swapped my stock one at 65k miles with the JHM OD pulley as preventative maintenance and don't see this new one failing within the next 60k miles
