Results 1 to 35 of 35
    Mar 01 2016
    San Diego/CA
    Smoke and hesitation while accelerating on freeway.
    I have a 2007 Audi A4 B7 2.0T. It has 130K miles on it. It used to consume 1 quart of engine oil every 1000 miles.
    Recently I replaced following parts by my own:
    -Thermostat, because of cooling performance CEL.
    -Rear coolant flange as it was leaking.
    -Vacuum pump(update version) because the older one was leaking after re-sealing it.
    After all these I could see that oil consumption reduced. One day I was cruising at freeway speed and press the pedal little. Suddenly saw a lot of smoke coming out from the exhaust. Car hesitated a little but became fine after few seconds. Now same has happened 3 times in last month. I think it happens only at high speed after diving for some time on highway.
    Now I see smoke comes out in the morning on cold startup after sitting overnight. It lasts for few seconds after startup. You can see the video at:
    I read through forums and decided to do a dry compression test.
    Cylinder 1: 175
    Cylinder 2: 185
    Cylinder 3: 185
    Cylinder 4: 185
    The number looks good to me. But I see some oil on the spark plug and at the tip of coil packs. I am considering to replace spark plugs as they look bad now.
    Picture at: https://www.dropbox.com/sc/mqlbr00lv...8V1i9l-6nL5Qla
    It may be due to valve cover gasket leak. No oil leak on outside, though. PCV looks okay as it is only 10000 miles old and I tested it by blowing air from the end of "C" shape PCV plastic hose. No idling problem.
    One more thing I would like to mention here that when the car is idle I hear heartbeat sound near airbox(probably coming from turbo). This goes when car runs. You can hear in the video at:
    Car runs great without any other problem. All the services are done on time. My coolant level is ok and the color is consistent. No oil in coolant or coolant in oil.
    Any suggestion what could be wrong? Is my turbo starting to wear?
    Thanks in advance!
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    I'm having thr same issue as you i got my pcv installed yesterday at dealer for free. Then my valve cover is leaking so i smell it in the cabin like burned oil though it is a simple fix. The other part about your turbo going out i don't know but i did replace my DV and made a world of a difference indeed. Also did you replace you N80?
    Sent from my C5306 using Tapatalk
    Ivan
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by dalmation53 View Post
    I have not replaced my DV or N80. I will check it tomorrow if they are in good shape. Do you think these can contribute to smoking issue?
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    A heartbeat noise in the airbox may also indicate a pcv issue as a result of an excess of pcv gasses going through the rear pcv and into the turbo/intake side of things. It wouldnt hurt to change the diverter valve as well as the pcv valve. Good luck!
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Mar 08 2011
    union, nj
    Do you have a oil catch can? If you do then its normal at idle to hear the valve in the pic tube fluttering. If you have stock pvc, then there could be a problem.
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by 08 classic View Post
    I have a stock PCV. Just checked the breather tube and can see lot of oil inside it. Please see the picture below:
    https://www.dropbox.com/s/cuspmn91j2..._0055.JPG?dl=0
    Is it normal?
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by Denio24 View Post
    Thanks for your suggestion. Planning to change PCV, DV and valve cover gasket.
    Aug 19 2013
    Miami
    Quote Originally Posted by hemantpd1 View Post
    I already changed those 2 exept valve cover gasket but car seems more peppy
    Ivan
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    I would check your IC hoses because they're likely full of oil thats being sucked through the intake. I chased a similar problem for months on my car - turned out to be the turbo.
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Aug 04 2015
    Kansas City
    I had the same issue. Turned out that I had a crack on the underside of my valve cover. Replacing it made everything better again.
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by KJack View Post
    I am planning to change
    -VCG
    -DV
    -New spark plug
    -PCV+breatther hose
    I hope these will solve my problem. Will update this thread with results.
    Aug 04 2015
    Kansas City
    -VCG
    -DV
    -New spark plug
    -PCV+breatther hose
    Inspect the valve cover closely when you remove it to replace the gasket. It's probably cracked. Also be sure to drain the oil that is likely collecting in the intercooler pipe.
    Mar 01 2016
    San Diego/CA
    Thanks for the suggestion! Parts are on the way from ECS
    Mar 01 2016
    San Diego/CA
    I drained almost a half quart of oil from intercooler pipes. equal amount from both sides. Is it due to the turbo is failing or VCG? Picture at: https://www.dropbox.com/s/tpu0wgahd5..._0064.JPG?dl=0
    Aug 19 2013
    Miami
    hard to tell. what happens when you go wide open throttle?
    Ivan
    Mar 01 2016
    San Diego/CA
    The car is responsive in city riding at low speed. But at highway speed, if try to accelerate(sometimes only) then smoke and hesitation for few seconds and then it becomes normal.
    Feb 21 2015
    Rip City
    The VC is easy enough to take off and inspect. Put a new gasket on it while you're at it. Then clean out the IC pipes as best you can and check on it after a week or so to see if its still collecting oil.
    I swapped to a new VC a while back in hopes that it would fix this exact issue, along with a bunch of other shit. Unfortunately it didn't, but hopefully it will in your case.
    Aug 04 2015
    Kansas City
    In my case it was cracked valve cover that was causing oil to dump into the turbo intake and collect in the intercooler pipe. My VC gasket and turbo were fine. The cover itself was the issue due to the crack.
    Active Member One Ring IC Asmodai's Avatar
    Oct 03 2015
    Pennsylvania
    Have any of you changed to a billet aluminum VC? I'm curios/wondering if this fixes this (what seems to be an ongoing) issue. I have this issue with mine as well, the whole oil loss, smoke when I get on it, and brief loss of power.
    Sent from The Lands of Always Winter
    Mar 01 2016
    San Diego/CA
    Changed the valve cover gasket, spark plugs, coil pack, PCV, breather tube and hoses. Test drove the car on freeway. I always accelerated hard and it did not smoke. But, I will keep checking it. If it does not smoke over a month then I will assume the problem is sloved. Will update the thread.
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by IC Asmodai View Post
    Not sure how good it is. You can first change the VCG and see if it solves you problem. I changed PCV and hoses also along with VCG.
    Oct 03 2015
    Pennsylvania
    I'll def. try this and thanks for the update. Glad yours seems to be fixed, hopefully it's the same with mine.
    Mar 01 2016
    San Diego/CA
    Unfortunately, smoke came back yesterday when I was merging onto the freeway and accelerated hard. Unlike last times, it was not severe and hesitation was there for very less amount of time. Smoke was also less compared to last times before repairs.
    Till now I have changed following:
    1. VCG
    2. Spark plugs and coil
    3. DV
    4. PCV, breather tube and hoses.
    5. Cleared oil from intercooler(almost 1/2 quart)
    6. Cleaned the MAF
    I am thinking of logging the data using torque pro app. I believe following parameters are important:
    1. MAF air flow rate
    2. short and long term fuel trim
    3. RPM
    4. Speed
    5. Boost and vacuum
    6. MAP
    7. O2 sensor
    Anything else I should include to diagnose the problem? Is the severity of the problem is related to the amount of oil in intercooler?
    Aug 04 2015
    Kansas City
    I'm still thinking it's a cracked valve cover. Have you checked the underside for cracks?
    Mar 01 2016
    San Diego/CA
    Checked the VC yesterday. When I blow air from PCV end while blocking the rear PCV port, I see bubbles coming out of VC passage. It seems I need to change it. Will update the thread once I change the VC. Thanks KJack!
    Oct 04 2015
    New Jersey
    This is exactly what my car is doing, I can't find anything to fix it. I hope you figure it out because I can not.
    Jun 19 2015
    Parma, Ohio
    I'd check the compression and make sure the rings aren't sealing. It's easy to check. It will cause large amounts of smoke and rough eng conditions.
    Jun 19 2015
    Parma, Ohio
    It may be worst case but it's good to start their so you can x it out be for you just throwing parts at it.
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by Caconway2322 View Post
    First thing I did was compression test. Compression seems good.
    Cylinder 1: 175
    Cylinder 2: 185
    Cylinder 3: 185
    Cylinder 4: 185
    Jun 19 2015
    Parma, Ohio
    Cylinder 1 seems too far away. Put about a tablespoon of oil in the cylinder to help seal the rings then recheck. If compression goes up then you have bad rings.
    Jun 19 2015
    Parma, Ohio
    It's still not horrible. But def a bit low. Next I'd say Find a way to hook up an air line to the intake Home Depot sells expanding rubber plugs in the plumbing aisle. Block off intake at air filter and apply pressure and check for leaks in CAC system.
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    Compression numbers read good to me. I dont see a problem there at all...
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
    Mar 01 2016
    San Diego/CA
    Quote Originally Posted by AKO View Post
    I think tiny crack which I found in my valve cover is causing issue. I would change it in soon and update the thread.
    Mar 01 2016
    San Diego/CA
    Changed the valve cover yesterday...Heartbeat sound is completely gone and car is running better. Lets see if smoke comes back. Time will tell...
    Mar 01 2016
    San Diego/CA
    No smoke in last 15 days..issue seems to be solved...So the culprit was cracked VC...
    Thanks you guys for help!
