Results 1 to 16 of 16
Threaded View
    Feb 02 2016
    squeaking sounds from the front wheels at low speed, not braking
    Hi all,
    I have an audi a4 2011 awd P+ with 26k. Recently there is a low squeaking like sound (like metal rubbing against metal) coming from the front wheels (not sure which side) at low speed 5-15mph. I can hear it with the windows open. It happens at low speed (accelerating) and/or cruising with gas pedal not pressed. The sound stops when I press the brake. Any idea what could be the problem? I googled this and some said it might be grit stuck behind the dust guard. I would love to hear everyone opinion.
    Car is 100% stock, I believe the brake and rotor are original. Also when I had the car inspected at 24k, the brake and rotor are in excellent condition with plenty of life.
    Thank you all.
    update:
    So I took a video with the squeaking sounds. I apologize for the wind noise, but you can hear it clearly at 0:50-0:59. Thank you all in advance.
    https://www.youtube.com/watch?v=bSplKHc_YfM
    What could this squeaking noise be coming from?
    -Rusty rotors
    -U joints
    -other suggestion?
