Results 1 to 8 of 8
    Mar 04 2015
    Houston, TX
    Just busted the sensor during lower link install
    Put a bit too much into the prying and this just snapped. Anyone have a part number handy? I'm wondering if I could do something to keep it together while I get a replacement :(
    Mar 04 2015
    Houston, TX
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Looks like exactly what happened to this user's case. https://arijaycomet.com/2014/05/07/l...e-ff01-wheels/
    Good luck!
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    Quote Originally Posted by tph4m86 View Post
    Drill some small holes in the plastic and sew the pieces together with small wire or dental floss. Fill the voids with epoxy.
    May 20 2010
    Could probably crazy glue it together for initial placement, and follow what tenspeed had said.
    Established Member Two Rings jagata's Avatar
    Apr 15 2014
    So. Cal
    J B Weld (2 part epoxy) will fix it.
    Mar 04 2015
    Houston, TX
    I used plastic weld and some electric tape for the time being. Anyone have a part number?
    Feb 25 2010
    magimmeMVE
    Usa
    Audi dont sell the green part on its own so its the full sensor you will need to buy. Part number should be on it.
