To start, I just took it out of the box for the first time today, after receiving it in December. I bought it when it was on sale, but though my parents have a heated garage, the concrete is too cold to lay on for hours on end. Chose to wait until now.
Took it out of the box, and one of the top corner brackets was broken off in the box. It's not a necessary part of the support structure, so I installed the thing anyway, but it still sucked after opening a brand-new piece worth a few hundred bucks to find the plastic was cheap enough to snap during the 30 mile shipping from ECS (I live in Cleveland). Either way, I wasn't ecstatic.
Started taking everything apart, and it all went smoothly. Got the old grille off (pain in the rump), and after everything was off painted the crash bar (and then PlastiDip'd over the black heat-resistant paint). Perfect way to do it, in my opinion. If any stones hit it, it won't matter much. I bought some small-hole chicken wire to line in front of the radiator and intercooler, but ended up not even using it.
Next step was applying the S4 and Audi symbols to the grille. This was the worst part of the day. I grinded down the back of the S4 symbol, epoxy'd it to the grille, then strapped it down with a few straps so it won't move for 24 hours while the epoxy fully cures. Shouldn't be bad, in the end, but dumb that there's no bracket for this included. The next was the dreaded Audi rings. First off, they're horrible to try and get off the stock grille without breaking anything. I semi-broke one of the plastic retainer hooks, but it was still completely usable. Start to put it into the ECS bracket...and it broke probably 75% of the black clips on the cheap plastic bracket. Literally, the only way to get the rings onto the bracket is to push them to snap them into place...and it was too much pressure for the plastic clips to handle. That said, it doesn't matter...because they're not fitted correctly.
The hooks on the Audi symbol do not fit into the ECS-made bracket. Even after getting it all together, there was a *LOT* of play, because the hooks weren't snug up against the clips. I can't explain this very well, but without epoxying it all together, the symbol was entirely loose on the bracket. That was only the first issue I had with the bracket...it flexes when applied to the grille.
After screwing the symbol holder down to the grille itself (using the 3 screw brackets), it actually flexed the symbol holder convexly. This meant some of the Audi symbol detached from it, because of the play in the bracket. I strapped the symbol down to the holder and I'll cut the straps tomorrow afternoon (24 hours), but I'm not sure whether it'll hold there or not.
Pro tip: If you make a bracket for existing items, that bracket shouldn't flex when it's installed properly...since the OEM items won't flex with them.
Either way, I'm satisfied with the end result...just not completely by the ECS product. I feel like I could have gotten a Chinese knockoff for much cheaper that had some type of flush 4 rings holder, and even coming across the ocean it wouldn't have arrived with a piece broken off. I still like ECS, but I wouldn't really vouch for someone to buy this item from them in the future.
Obviously, pics:
In the garage
Just put it in the driveway
