Results 1 to 6 of 6
    Sep 28 2009
    suburb
    1136 and 1138 codes ONLY at full boost and throttle
    My car has been throwing these two codes. I notice they ONLY appear when I floor it and typically in second gear going to third and it is full boost at say 22 lbs boost. Is this a vacuum leak? Doesn't throw me codes any other time.
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Jul 04 2012
    Woodbridge, VA
    What are the code descriptions? Too lazy to look them up.
    Sep 28 2009
    suburb
    lean codes.
    Audi SQ7
    Audi B8 S5 (gone)
    Aug 25 2012
    Elmore alabama
    My guess would be boost leak of the issue only happens in boost
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Do you have vagcom or a way to check measured value blocks? If so check block 32. The first and 2nd % will be short and long term fuel trims bank 1 and the 3rd and 4th are short and long term bank 2. You should term should be +-5% your long term is +-10% if your + than you are adding fuel due to a vacuum leak, clogged fuel filter, bad fuel pump or could be bad Maf. It could be tuning if you are in the middle of tuning it but may not be if you havnt had any revisions lately.
    Sep 28 2009
    suburb
    I will look at the values and I do have a vagcom. I have had fuel pump replaced, new MAF, new wiring harness. I had a coolant leak that migrated up to the ECU and cleaned all connections with deox. I used to have rough idle and misfires, but that has seemed to go away with deox cleaning. So now it is either ECU damage or leak.
    Audi SQ7
    Audi B8 S5 (gone)
