Results 1 to 4 of 4
    Senior Member Two Rings a4ced's Avatar
    Mar 07 2016
    Lehigh Valley PA
    Coolant Temp Sensor Vs Rear coolant flange
    Alright so I am a little confused. I had the coolant Temp Sensor replaced. Is there a separate o ring for the coolant flange itself? My leak hasn't gone away after the temp sensor was replaced and I want to try anything inexpensive before I have to look at the heater core.
    This is what I was told I needed, but I don't wanna buy it if I dont need it.
    Sent from my SM-G928P using Audizine mobile app
    Oct 16 2008
    South Florida - Ft Lauderdale
    You leak was probably not coming from the temp sensor but the coolant flange itself
    And as you can see on the pictures you posted, the oring comes with the new flange
    PIA to access, easy to replace
    Phil
    Mar 07 2016
    Lehigh Valley PA
    Okay thank you just wanted to make sure I order the right thing. I appreciate the help!
    Feb 15 2016
    Cambridge,Ontario
    I'd be checking your vacuum pump for leaks since you are ripping all that out anyway. Having done the timing cover once I'd even take that off just for easier access.
