Results 1 to 4 of 4
Thread: wheel spacers
    Oct 27 2015
    Latvia
    wheel spacers
    Can you please add some pictures here of your S7,RS7 with wheel spacers. I'm running 10mm rear but thinking of going to 12,5mm or 15mm.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Just a thought, you might have better luck just Googling "S7 ET30", "S7 ET 25" etc. and then just picking up spacers to reach your desired offset with the wheels you have. I just mention this because you'll get results from people with spacers as well as those with no spacers but aftermarket wheels of different offsets.
    Established Member Two Rings JS300's Avatar
    Apr 01 2015
    NYC to Seoul
    Here is my RS7 running 17.5mm spacers all around, lowered via VCDS. It's not that aggressive and doesn't rub at all.
    Established Member Two Rings ekpyr's Avatar
    Jul 16 2007
    Long Beach, CA
    wheel spacers
    I'm running 10mm front and 15mm back with stock 21" wheels, stock Dunlop 275/30 tires and KW HAS suspension on DRC and get rubbing on front during canyon carving and occasionally on the rear on big freeway dips.
