Results 1 to 40 of 51
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    12.8 @ 109 Stage 2...
    Just got home from the track. Had lots of fun but also had some less than desirable numbers. As of yesterday my car was flashed EPL stage 2 with CTS intake.
    Drove 45 minutes to the track, checked in, went right to the line with minimal time to cool down... [email protected]. Get the slip, I'm thinking ok my car just needs time to cool down. Pop the hood and let it sit.
    Fast forward two hours, car has definitely cooled down a bit and temps are dropping. I'm ready for a good run... [email protected]. Both runs had 1.9 60ft time which is likely part of the issue.
    I had a bit more fuel than I probably should have (between 1/4 and 1/2 tank) but that probably wasn't a huge factor. Also I have very minimal drag racing experience. Both runs we're done using launch control which held me around the stock 3200rpm and ,to my knowledge, I didn't have any wheel spin. Another thing to keep in mind is this was the 3/30 TCU file. I didn't find out I had 4/28 until 5 minutes before I had to leave. Maybe the newer file would have helped and possibly launch higher? I could be wrong but I'm pretty sure the car, in "S", shifted before 7100rpm on gears 2+. But yet in manual I am able to achieve 7100rpm on gears 2+. Another possible part of the problem.
    All numbers aside, I am very happy with how strong the car feels but yet it's only 2 tenths quicker than stock? I'm excited to hear some feedback, diagnose the issue, and get back on the track!
    Edit: I myself didn't actually flash the car. The owner of the shop that I take my car to did after he put the pulley on. I walked him through it on the phone and specifically said "click the stage 2 file". Could he have possibly fat fingered it and pressed stage 1?
    [IMG][/IMG]
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    That 60' is not that great if you were using LC? With nothing ore than a CW piggyback I was getting high 1.7's and running 12.6x@108 (high 108's at that ). Do you know what the DA was? It can make a ton of difference in how the car performs. Your times are certainly in line with Stage 1 tuning, stage 2 should be performing significantly better.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    My car short shifts on launch control, I wonder if yours is doing that too? Waiting for a fix from EPL.
    Still I'd expect more mph. Your conditions look solid.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Established Member Two Rings deadpool7777's Avatar
    Dec 01 2014
    Wife's econobox... Poor man's tool kit...
    Tacoma, WA
    It took a few days for me to actually feel the full potential of my stage 2 from EPL.
    Apr 14 2016
    Austin Texas
    Yeah...something might be up. I just got back from the track too...did 109.5mph and a 13.0, on stage 1, but DA was an awful 2750.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Apr 14 2016
    Austin Texas
    Or just might need adaptation time
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    What were your IAT's? I know you said you cooled down the engine, but from my logging, having the car sit with the engine off does not help lower IAT'S with a stock cooling system (actually increases it) FWIW.
    Your D/A's are enough for a low 12's in a strong file on 93 octane stg2, and a 3,200 rpm launch control isn't enough to spin (you may benefit from a 4000-4500rpm LC actually to lower 60ft times, and therefore lower your 1/4mile and overall trap)
    In comparison, I ran [email protected] with an older EPL stage 1 in similar D/A's when I had mine with a OEM tcu.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Feb 20 2012
    e90 M3
    NH
    Quote Originally Posted by MVR 155 View Post
    DA is listed as effective altitude on the slips I believe. Conditions were certainly not terrible especially the second run.
    Feb 20 2012
    e90 M3
    NH
    Quote Originally Posted by Loe View Post
    Unfortunately I had no way of measuring IAT's so that I cannot tell you. Like you said, on a revised TCU tune w/ a higher launch, the 60ft should come down to where it needs to be.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Something is way off here...my stage1 91 octane car went 12.31@ 111mph. Even assuming he accidentally loaded a stage1 file, you should be faster. I would contact tony and he will help you out.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Apr 14 2016
    Austin Texas
    Quote Originally Posted by BlownOne View Post
    what were DA'S with that run?
    Dec 30 2015
    Sacramento, Ca
    I posted in the 1/4 thread, but around +350 da iirc.
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Probably short shifting with launch control which is causing a terrible 60 and overall bad time.
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Feb 20 2012
    e90 M3
    NH
    Thanks for the responses guys. Yes I will double check to make sure stage two tune is installed and I will check with tony regarding updated TCU tune. Can't wait to get back out there! Any other ideas?
    Apr 01 2011
    B5 on jack stands
    charlotte
    Quote Originally Posted by importraceram View Post
    torque app could give you useful info like IAT's
    powered by
    Hot Boi parts
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Flashed stock file lol?
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    You're in NH? Epping is notorious for bad times...
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Apr 14 2016
    Austin Texas
    Nice. We won't see da's like that here in Texas until late fall. If ever. Gives me hope tho. Car ran 13.0 last night at 109.5 on stage 1. Would think that puts me at least half second quicker in decent air.
    Sent from my Venue 8 7840 using Tapatalk
    Feb 20 2012
    e90 M3
    NH
    Yes ran at New England Dragway.
    Aug 11 2015
    Alberta
    How does a track affect MPH though when conditions are good? a 1.9 60' is one thing, but a 108 trap seems slow too.
    I'd expect a 93 octane, Stage 2 with TCU to be 115+.
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Ya that's not great...stock for the B8.5s is listed as 12.9 quarter. There's no chance you should be running 1/10 faster with a stage 2, unless the DA is horrible and your tires aren't keeping contact.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    It's power related.. Either something is triggering to dail back power or it's not there.
    The back end of the track you're losing 1 tenth.
    Look at your 1000 and then your et. Conditions are ok, you can also be heat soaked, but something is pulling power.
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jul 21 2004
    South Florida
    Its a track at sea level in a decent DA so yeah, the trap speed looks a little less than what you'd like. A better launch would help the ET. The best thing for any of us looking to make decent times is to log the car to see how its doing. Ultimately, there are just as many stage 2 cars that run mid to high 12s as there are that run low 12s to high 11s. The environmental conditions (yours werent bad) and the condition of the car can make a huge difference in power. Log, log, log.
    Mike
    2018 Audi S5
    Gone-
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by cjw View Post
    Track prep will not have any impact on mph and 60' only effects et.
    Aug 11 2015
    Alberta
    That's my point. Saying it's a slow track really doesn't mean anything if the weather was favourable.
    Feb 20 2012
    e90 M3
    NH
    Yeah seems like bottom line is the car is just not producing power...
    Senior Member Two Rings roadawg's Avatar
    Jan 09 2015
    Put 5 gallons of E85 and I'd bet money you would gain 3 + MPH.
    If its not fuel related, something else is off causing boost or timing to be pulled. Agreed on the logging, you are leaving a TON of power on the table.
    2012 S4 - Man pedal, sport diff, APR tune, Meisterwerk SS, AWE Exhaust & other goodies.
    Senior Member Two Rings A4SlineWA's Avatar
    Aug 05 2015
    WA
    I feel your pain. Im running a Solomotorsports tune from the previous owner and ran a best 12.7 @108 on my 2011 DSG S4. Stage 2/APR pulley. I wasn't too happy because my friend who went and didn't launch got a 13.2 @107, stock. I asked Solomotorsports for an updated tune and got a best 12.6@110. Not much difference. I was going to go with EPL but your numbers seem like mine.
    I too felt that with the updated tune no TCU tune, using lunch control, I too noticed the car wouldn't shift all the way to redline on 2nd or 3rd gear.
    Here is my thread. I created similar to yours. http://www.audizine.com/forum/showth...ighlight=Upset
    -RS4 Piano black grill -Stvbek Carbon Fiber Lip -19x10 Niche Targa wheels in Anthracite -20% -LED foglight and tail plate conversion -Inverted black/red supercharged badges -Interior LED lights -Solo Motorsports Stage II tune: APR pulley, belt w/ MAP programmer -93 OCT tune and Stock tune -APR Stage I + II Carbino Intake system -H&R Sport Springs -AWE Tuning Touring Exhaust
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Seems like the car isn't making power
    My 6MT revo 1+ did [email protected] MPH with a poor DA & damp UK air running E10 fuel
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by bhvrdr View Post
    Mike
    +1, hard to tell anything at this point without logging for sure as it tells you how the car was performing during that particular run.
    Feb 20 2012
    e90 M3
    NH
    Quote Originally Posted by A4SlineWA View Post
    I wouldn't shy away from EPL just because of my two runs Friday night. I have no doubt that this will get sorted out and I will be in the "normal" stage two range. Customer support/service has been tremendous as well so I have faith.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    JDrove 45 minutes to the track, checked in, went right to the line with minimal time to cool down... [email protected]. Get the slip, I'm thinking ok my car just needs time to cool down. Pop the hood and let it sit.
    I don't think it's heat. I ran my car a couple weeks ago 12 passes down the track with groups of 4 runs each and all four were within 1 10th of one another. It's not the heat of summer here but I was still surprised she never seemed to be impacted.
    Definitely not he norm for a Stage 2 car.
    I ran mine with a full tank of 93 only and tires at 41lbs and pulled 12.2's at 113-114mph. Best 60ft was 1.887 so that kept me in the 12's for sure. Did so just to see how she would run as I keep her every day on the street as a daily driver.
    Definitely something up. I have APR's LC set for 3-4-5k launches and even 3k I spun just a bit. 4k I spun all over and ran a 12.6 with a 2.0 60ft. My best runs ever are without LC.
    Quote Originally Posted by demonmk2 View Post
    Torque on my car only measures airflow rate not temp. Couldn't find where to get that at.
    Yep. Best I ran last fall was 11.9 at 115mph at a different track than above with tires at 34lbs and 1/2 tank fuel.
    Quote Originally Posted by roadawg View Post
    SC Belt slipping maybe?
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Sounds like these off brand tunes are not the way to go. Even APR and GAIC has issues but they weren't that bad from what i remember. I would be super pissed for paying all that money and getting 0 results. You should be in the 11's. I think when i get a tune I'm going to go with GAIC.
    Nov 29 2013
    Silver Spring, MD
    Couple of EPL guys ran really good times, so I wouldn't write them off yet. Solo, on the other hand...
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Apr 01 2011
    B5 on jack stands
    charlotte
    on your torque app do you have the free bee app or did you buy it?
    you should be able to look at the iat's on the raw data display or add a display just for that reading.
    powered by
    Hot Boi parts
    Veteran Member Three Rings BDP's Avatar
    Feb 07 2015
    Ohio
    Quote Originally Posted by pdqgp View Post
    Are you running at National Trail? Just curious...Kilkare is 20 minutes from my house so I usually go there. I've been trying to go and baseline but this Ohio weather...
    I've always ran my fastest times at Edgewater down towards Cincinnati.
    2018 Glacier White RS3 - Unitronic Stage 2 (E85) ECU, Stage 2 TCU
    2014 Estoril Blue S4 (DSG) - Sold (11.2@121mph 93 octane)
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    We recently did some logging on my EPL tune and saw that the car was not bleeding boost but it was being conservative on the timing. I'm going to get with Tony on Monday and see if he can add 5-6 degrees of timing to get my car running properly.
    Comparing tunes, the EPL tune makes much more low/mid range torque than my Revo tune. But overall the car is a tad slower because it's not making as much power at high rpm. Hopefully adjusting the timing values will correct my problem and for reference my Revo tune went 12.6@112 with a crappy 60' and 93 octane. My EPL tune does not seem as quick even with an E85 mix 😠
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by BDP View Post
    I do both. We did trails on the 12.2 runs. Kilkare is where I ran 11.9. Never been to edgewater. If you ever go pm me. I'm always up for a trip. We could get a few of together even.
    I'll pm you when our group charters out Kilkare. We do 3 or 4 events per year. 75 or so cars and we rent the entire track for us. Costs vary but you'll get 25 runs in if you want.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Veteran Member Four Rings hodrosS42001's Avatar
    Mar 18 2012
    New Jersey
    Do you have a boost gauge? Was it boosting properly or bleeding boost? Something isn't right.. No offense those runs were sh*t.. Are you sure you were on the Stage 2 tune and not stock for some reason?
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Obviously somethings not correct here. This is basically the same file that we went 11.8 single pulley on pump gas with. Call in Monday.
    I'm out of computer/cell range the rest of the day or I'd try to get with you today.
