ok fellow enthusiasts, I have not thought of everything which is why Im looking for a random shot into left field one here. I have a 2001.5 manual stage 3 SRM k24's, 3 bar map sensor, awe intercoolers, samco hose set, jhm im spacers, 88mm maf housing, awe s flo intake, awe downpipes with hi flow cats and exhaust, walbro 450 lph pump, bosch ev14 60# injectors, modified im to set injectors into manifold completely, apr bipipe with r1 dv's and i just slapped a new spider hose in. I have pressure and smoke tested the bageezus out of everything. I have found no external leaks to this point.
now for the good stuff, I hit 25 psi like im tuned for, then carry it until I hit appx 6k rpm.....then drops off to 15 psi......is there something im missing.... all my numbers look great until then, then like a lipo battery in an rc car hitting low voltage cut, she just drops to 15 psi and its almost dead on at 6k. somebody give me a path... my brain is mush right now and Im looking for input.
thanks in advance.
