Results 1 to 10 of 10
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    Thumbs up Got my Carl phone mount - beyond cool
    OK, the phone mount arrived today and wrapped to travel the globe. Opened it up and said, "Wow, the simplest solution is typically the best". Went out to my car and it took me about 2 seconds to remove each vent, being careful to pull a little all the way around, a little at a time. Vents came out very easy. Then I just put the phone mount up to the dash and inserted, carefully and slowly the first vent, making sure the orientation was correct. Then the second vent and just like that it was installed. I checked vent operation and made sure the vents were pushed in flush all the way around. Then I put my phone on it and out holds it very nicely. I did insert the provided thin rectangular piece of steel between my phone case and the back of the phone.
    I want to post pictures but for some reason it says I am not permitted to post pictures at the bottom of the screen under permissions. What's up with that?
    Anyway, this a well thought out perfect solution for our cars and our phones.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    You need to post pictures on another services like Flickr, Imgur, Photobucket, Instagram, etc and then add the URL to the image file here. It's a bit of a pain and a pretty common question.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Aug 06 2012
    san diego
    w00t!
    Active Member Two Rings Tdub Lion's Avatar
    Feb 26 2016
    Knoxville TN
    Quote Originally Posted by phillyquattro View Post
    Or just download tap talk and post directly from your phone gallery.
    Sent from my VS986 using Tapatalk
    Feb 15 2016
    Los Angeles, CA
    Do you have an iPhone 6 or 6 Plus?
    I have a 6 Plus, and when I hold my phone up between the air vents.. it doesn't look like it really fits well between them.
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Quote Originally Posted by sjh13 View Post
    I have a 6S plus it fits fine. Even works in landscape mode. Take a look at this thread. It has pics.
    http://www.audizine.com/forum/showth...SIIIIIIIIIIICK
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Quote Originally Posted by Baggio View Post
    i would like to know how you have it fitting in landscape mode, there is no way my note 5 will fit, it hits the vents and doesnt allow the magnet to grab
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Aug 28 2013
    Quote Originally Posted by saxon View Post
    Don't rotate on the magnet. Remove and place as shown. Below.
    Aug 06 2012
    san diego
    how did you get it to fit landscape?
    Aug 28 2013
    Quote Originally Posted by markn1689 View Post
    I couldn't get it to fit, when I rotated when it was already on the magnet. So, I took it off and put it on directly like it is sitting in the photo and it worked.
