Results 1 to 16 of 16
Thread: Rust spots
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Rust spots
    Curious if anyone knows what these little spots are in my car and if in fact they are rust spots. After giving my car a good cleaning after winter there is little rust specs all over the paint, it's white so i can see it very clearly. I took my nail to it and it scrapes off but would be a pain in the ass without a porter cable to get off.
    Does anyone have any experience with this or any tips on how to get it off easily?? I know I can get it off with a pad but don't have one that is easily accessible. Thanks.
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Rail dust
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    May 07 2013
    Northampton, MA
    Likely ferrous particles look up a product called CarPro Iron-X
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Rust spots
    Quote Originally Posted by theswoleguy View Post
    Rail dust
    Can you elaborate? Tiny little metal fragments? Why have I never got this on any of my other cars? It's literally everywhere on the car with exception of the front, hood, and top of the car.
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Quote Originally Posted by Zackb911 View Post
    This stuff seems pretty serious.
    May 07 2013
    Northampton, MA
    Iron-X is super easy to use and comes in VERY handy with a white car. Buy some and follow the instructions - you'll be amazed and won't regret it.
    Mar 21 2015
    Quote Originally Posted by Whitee View Post
    It is serious and seriously good. I have had two white cars and this stuff works. The crap on your car is fallout from the air and your brakes. Most white cars see more of it on the rear of the vehicle because of your breaks. You might have to agitate the heavier spots to get them off with the iron x. Use the iron x before claying if you go that route.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    You need to clay your car.
    I get them also - it's metal particles in the air that are "sticking" to the paint. It shows up a lot on white cars.
    Mar 21 2015
    Heres my Audi after a year. Iron x goes on clear and turns purple while doing it's job.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    It's definitely easier to see on white. It's a combination of brake dust and other metal particles in the air that build up on the paint finish.
    Iron X or Iron Out will take care of a lot of it, and then a clay bar (or a Nanoskin Autoscrub- synthetic clay bar) will take out the rest.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    brake dust.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    As others have noted, it's a combination of industrial fallout, rail dust, brake dust, etc. Basically metal flakes that are getting embedded into the clear coat. Use CarPro Iron-X to remove it. Use it outside and be careful not to inhale it. CarPro TRIX does both Iron and Tar, works great for the lower body panels. Be careful on both to avoid any black trim up front as it can stain it. Clay the car after and then hit it with polish to remove the marring from the clay.
    It's important for any and all cars to have these contaminants removed as they can and will make their way to eventually contaminating under the clear coat and causing issues later. Rust, clear coat failure, bubbling are all common results you will see occurring if left unaddressed.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Apr 05 2014
    Houston, TX
    Mine is an ibis white S4 and had the same issue. In my case, I didn't have to use any other chemicals and simply clayed the car. One piece of advice is not to use the spray wax/detailer that most clay kits come with, but instead just have a soapy water bucket handy and squeeze out some soapy water on the area you want to clay. It works just as well (the ultimate goal is just to have lubrication, no need to waste the more expensive detailer/spray wax) and it come off with little effort. Just remember to seal/wax afterwards!
    2016 Audi S3 P+ / Brilliant Black / Black Optics / Teknik / S Sport
    Previous:
    2011 Audi S4 Prestige / Ibis White / DSG / Sports Diff / Chipwerke S
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    I'd say claying isn't necessary for it. As a few have said, IronX is the way to go. This happens to every car, you just don't see it on cars that aren't very light-colored, as well.
    Wash your car well, apply IronX to just about the whole thing (spray it like a madman), let it sit for 5 minutes, then rinse it off. The car will look like the Good Lord intended.
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Quote Originally Posted by hotleadsingergu View Post
    Appreciate the advise guys, will give the IronX a try. This stuff looks to be pretty awesome based on reviews and what you guys have said.
    Veteran Member Three Rings 968Reckless's Avatar
    Sep 25 2010
    B8.5 S4, Porsche 993, BMW E30 s52 swap, BMW E30 vert, BMW 2002tii, gen 3 tacoma
    Syracuse, NY
    Brake dust + white car.
    You can use car pro or Adams polish wheel cleaner...their new stuff is blue. Either option I usually dilute it with a little water. Make sure you clean it ALL off when done, don't use it in direct sun light.
    Sent from my beeper
    @martino_motorsport
