Results 1 to 3 of 3
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    power windows, sunroof not working
    nothing works (no door switches, no sunroof switch).
    Not sure if there is a module in VAGcom to use for the power windows/roof.
    Could find in comfort module (35).
    drive side side panel fuse box does not have a power window fuse sliding roof fues (no 30) is good.
    Suggestions?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Mar 26 2015
    Connecticut
    Did you find out any info? I have the same problem now. Sunroof fuse keeps blowing and can't roll any window down. Can't find the power window control module anywhere or comfort control module. Any help would be great. For a 2000 audi s4
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by logan199 View Post
    I swapped out the comfort control module (side of passenger side trunk, easy to get to and get out). That fixed the windows/sun roof issue. But now rear doors are locked out and can't open (not even from inside).
    Only possibly explanation I have is combination of a) child locks were active and b) the used module I swapped has a weak pump that cannot generate enough (pressure? vacuum?) to get the rear doors open (I DO have a leak in the system!).
    05 Golf TDI
