My pad composition is exactly as per
www.supercars.com. it's the top Australian racing car series using relatively heavy raceways. They have copies of the S6 c7 front brake pads design so they can now Supply front pads with the same compound. I dont think you will find another pad that comes close to this. Message me for details.
They may have the RS pad backing design. If not, sending them your old pads and they will copy the backing plate at which time anyone can then order them.
My understanding is rotor heat soak is not what's causing the squel. It's that the pads overheated. You will find the pads now don't quite bight the same on light braking. My understanding is heat sock is due to stopping with hot rotors with the pads/calipers keeping heat in that part of the rotor (on track days make sure you do a cool down lap before stopping and do not apply the handbrake)
Eventually I ended up buying new rotors and use them for everyday use. The old rotors are for track days and that will last me the life of the car. Overall much cheaper option.
R spec tyres are hard to find in a size that fits over our calipers. Ideally low profile tyres are not the best option for tracks. 18inch rims or 19inch are best to give the tyre walls some play (R spec tyres have much more rigid casings and operate on approx 25psi cold). I purchased after market audi 20inch rotor rims (as 19inch won't fit). Tyres are Continental ContiForceContact R spec 255/65/20. These are the only R spec tyres I could find in this size. I drive the tyres to and from the track as they are still groved enough to be road legal.
