Results 1 to 4 of 4
    Mar 08 2014
    GVA/Canada
    255/35/19 vs 245/40/18 for OEM sizes - why not 255/40/18?
    I did a search for this but couldn't find what I was looking for. Having said that, maybe this already exists and has been discussed?
    My S-Line Competition package came with 245/40/18. I wanted the 19's that came with 255/35/19 but whatever...
    I'm wondering why the 18" size isn't 255/40/18? This matches more closely with 255/35/19. Or by that same token why aren't the 19" 245/35/19?
    Seems odd the tire sizes don't match with respect to circumference.
    This also leads me to question whether there is a VCDS setting to specify which tire diameter you have?
    Any insights?
    2018 Q7 - 3.0T - Glacier White - Progressiv, S-Line, Black Optics, LED
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Coming form the B7 section, so forgive me with model specifics.
    are your 18's 8.5" or 8" width? IMO, 255 on a 8" wheel is pretty wide (quite a bit of shoulder).
    Also, I've never heard of VCDS telling your car a wheel size. I'm pretty sure your car doesn't care WHAT the circumference is as long as the circumference on all 4 wheels is +/- 3% or EACHOTHER (IIRC)
    Really, you can do pretty much whatever you want (within reason) in terms of tires. willtheyfit.com is a good resource to check sizes as well.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Mar 08 2014
    GVA/Canada
    ^ forgot about the wheel width. Mine are 8" which explains the 245. However, this still doesn't explain why Audi didn't match the different tire size options in terms of circumference. I still find that odd.
    255/35/19 = 255/40/18
    245/35/19 = 245/40/18
    I know it likely doesn't matter I'm more curious than anything.
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    Im pretty sure the stock 19's are x8.5 thats why they can run 255 on 19's
