Results 1 to 26 of 26
    Feb 23 2013
    2016 Audi S6; 2015 Toyota 4Runner TRDP;2013 Toyota Prius; 2014 Yamaha FZS Waverunner
    Sinking Spring, PA
    2016 Audi S6: Emissions Testing in PA
    So I am trying to have my car inspected for State Inspection and Emissions and for some reason my car can't get tested for emissions because a certain number of readiness monitors must be active and apparently not all of them on my car are active. Does anyone have any idea how to reset them or get them active? I am not running any codes or CEL so I am not sure what to do. I am APR Stage II with the downpipes. Thanks in advance.
    2016 S6 Prestige | Sepang Blue | Black Optics | Driver Assistance | Sport Pkg | B&O | Comfort Seating Pkg | Carbon Inlays | Night Vision | Alcantara Headliner | OEM RS6 Grill | OEM RS6 Carbon Fiber Mirrors | AG M580 Brushed Tinted Clear | AWE Touring Exhaust | AWE S-Flo Intake | XPEL Stealth Wrap | APR Stage 2 ECU/TCU Tune | APR Downpipes |IG:Chudiddy_S6
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    This is likely an issue with APR turning off the cat efficiency and rear o2 monitors.The easiest thing to do would probably be to switch to stock mode and then use rear o2 sensor spacers if necessary. I know they use high flow cats, so you may be able to get by without the spacers.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Feb 23 2013
    Sinking Spring, PA
    So I don't have to flash back to stock, I just need to switch to the stock program then re-test? If this is the case, when I switch to the stock program, how long before the monitors are active? Must I drive a certain amount of miles before re-testing for emissions? Thanks
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Hate to say it, but you will fail emissions testing with stage 2 downpipes and software. That's why I haven't done it. The tune switches off the post cat O2 sensors, so these sensors are not read as "ready". You will fail the "readiness" part of the OBD based emissions test.
    If you switch to stock mode with the downpipes in place, all your sensors will function normally, but the high flow cats will likely trigger a cat efficiency below threshold code.
    The solution is to run some O2 sensor spacers which will fool the sensors. This should do the trick but is no guarantee.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Quote Originally Posted by chudiddy View Post
    I find it interesting that a 2016 car has to go thru emission testing. In CA a new care is exempt from emission testing for the first 5 years and then every 2 years starting at year 6. Hope u are able to come up with a solution with your after market down pipes.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Darn. I just placed an order for stage 2 and downpipes. In Las Vegas I will need to deal with emissions as well. Following this thread for solutions.
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Mar 14 2008
    MA
    Quote Originally Posted by jrsAudiA6 View Post
    Massachusetts has OBD based emissions testing as part of your annual state inspection also, starting from the time you buy your car.
    Quote Originally Posted by Avned View Post
    O2 sensor spacers are your only bet. They may work, they may not.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    VVG raised this issue several times when APR first announced the downpipes and the response was radio silence. That's a pretty major annoyance.
    Feb 23 2013
    Sinking Spring, PA
    Link to said spacers please
    May 08 2004
    NoVA
    No personal experience, but one of many that surfaced in a Google search. What's alarming is that most seem to go out of their way to say it may not work. Anyone offering downpipes needs to factor in a solution for this issue, and they better not hang their hat on that "off-road only use" bullshit. They are well aware that the vast majority of S6 or RS7 users are daily driving their cars.
    http://www.uspmotorsports.com/Audi--...90-Degree.html
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Feb 23 2013
    Sinking Spring, PA
    Quote Originally Posted by Brooklyn View Post
    So the disclaimer at the bottom of this product states that if I am running APR software, I do not need this spacer. I wonder if I just switch to stock program and re test, if it will work. I'm gonna give that a try first and see what happens. I will report back.
    Mar 14 2008
    MA
    I think it might be of interest to the whole community here to see what happens if you run stock mode for a few days with the downpipes and report back as to what happens. CEL? Fault codes? Or is everything kosher.
    Active Member Two Rings audic7s6's Avatar
    Apr 06 2016
    2013 Audi s6, 2014 Bmw 328 sports wagon, 2016 lexus gx460
    nj
    Any luck on passing the emissions test?
    2013 Audi S6. APR stage I, AWE touring exhaust, AWE intake, airmatic lowering links, Eurogear CF front spoiler, Eurogear rear valance, black optic wheels.
    Feb 23 2013
    Sinking Spring, PA
    So I passed emissions and averted a mini crisis. LOL.
    Switching back to the stock program allows the "02 heat sensor" monitor to be ready thus alllowing the car to be tested for emissions. The "o2 sensor" monitor was still inactive but enough of the readiness monitors were ready for the test to proceed. Tested, passed, then switched back to 93 program. Piece of cake.
    May 08 2004
    NoVA
    Glad it worked out for you!
    Sep 04 2011
    Central NJ
    Could you please clarify? Did you just switch to the stock program (i.e. one of the four programs loaded by APR) and wait for the readiness to set or did you flash back to stock at the APR dealer? I assume you din't use any O2 spacers. I'm planning to get APR downpipes and APR stage 2 tune next week but don't want to find out down the road that I can't pass NJ state inspection.
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by hmuller View Post
    I'm following this thread too! My guess is that he just flashed backed to stage 1 software (not going to APR dealer) because that stage 1 file won't have the 02 sensor coded out. It will eventually throw a cel but if you time it right you can just go back to stage 1 tune and do your emission test. Total guess on my part but I have been doing a ton of research on this as I just got my downpipes. I haven't heard of anyone using spacers and actually having success for what its worth. Tons of people will recommend them but haven't heard of anyone actually using them and avoiding a Cel.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Sep 04 2011
    Central NJ
    Quote Originally Posted by Djpeaksd View Post
    Just had a PM from chudiddy and can confirm that he just used the APR app to select the stock file and clear all error codes. Then he drove around for a day or so until enough readiness bits passed and went to emission inspection which he passed right away.
    Senior Member Three Rings Prh's Avatar
    Mar 28 2015
    Q5, Land Cruiser 200, John Deere
    Northern VA
    I got the rejection today during VA emissions test. Heat Sensor and O2 Sensor not ready.
    Running APR Stage 2 and downpipes. No spacers. Will try what chudiddy advised, select stock program and drive around a day.
    Anyone know if you can read when these sensors are “ready” with VAGCOMM? If so, what locations?
    Would like some assurance before I pull up to emissions test for the 2nd time.
    2014 S6 Black - APR Stage 2 ECU+TCU, APR DP, AWE Exhaust, HRE-FF01, Black Optics, P3, ALP, Escort Redline 360, Blackvue, 034, carbon diffuser, carbon mirror covers, Roc-Euro intake, ECS Tuning sways, H&R lowering module
    Senior Member Two Rings mwmaroney1's Avatar
    May 08 2012
    2014 S6
    Edit
    Sep 04 2011
    Central NJ
    Quote Originally Posted by Prh View Post
    In VCDS go to the engine module and click on Readiness.
    Dec 12 2016
    ny
    If you have a friend or a willing shop, the secrete in PA is as follows: when emissions machine prompts you to plug in the OBD connector, don't. Then click continue, you will get en error that the machine doesn't sense a connection and to try again. Repeats this (3-6) times, then the machine will tell you that the OBD connector must be damaged and it will put you into manual mode, I.e ask you a series of yes/no questions like is there a check engine light, does the vehicle have a CAT. And boom you have just passed your emission test. I know this because I had a PA inspection license and I am saying it because I no longer have to work in the indistry.
    Jun 30 2016
    NNJ
    There are O2 sensor spacers made now with mini cats in them. My mechanic has put them in quite a few cars and said that they work beautifully.
    Mar 28 2015
    Northern VA
    I called my local shop, NGP. They advised me to revert back to the stock program and drive it around for a day or so. That worked, I passed VA emissions today.
    Thanks hmuller for also confirming the VCDS Readiness. I confirmed as I was sitting in line waiting for the test.
    Sep 04 2011
    Central NJ
    Just to be clear, did you just switch to the stock program with your cruise control stick or actually go to an APR dealer to flash back to stock?
    Mar 28 2015
    Northern VA
    I switched to stock program using APR dongle via my iPhone. Not a dealer flash back.
    Sent from my iPad using Tapatalk Pro
