Results 1 to 9 of 9
    Senior Member Three Rings AznSensation87's Avatar
    Aug 16 2012
    MA
    Tire replacement
    So about two weeks ago, I wound up getting a flat tire on my passenger front due to my valve stem leaking air. I didn't know my tire was flat at first, and wound up driving on it for several miles (maybe ~6-7 miles?). I eventually got the valve stem replaced and now it drives fine. However there is some questionable sidewall damage on the tire, so I am looking to get it replaced just to be on the safe side, as I will be participating in some rallies this year.
    My main question is...can I replace just the one tire with our Quattro system? I currently have Michelin Pilot Supersports and was told I still have a good amount of tread left (new is 10/32, my fronts and rears have about 5 or 6/32 left). I would like to use my remaining tires if possible if replacing one will not cause damage to the system. I've asked multiple places, where one shop said I would need to replace at least two tires, an Audi dealership said replacing one would be fine, and reading online it says all four should be replaced. So which should it be??
    2013 Audi S4 | 6-MT | Monsoon Gray | APR Stage II Tune + Pulley | Roc-Euro Intake | Diamond Black AWE Exhaust | 19" TSW Nurburgring gunmetal on Michelin PSS
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    I guess this is situational and dependent on remaining tire tread.
    I've replaced just one tire. One of my stock Continental DWS tires hit a pot hole and caused sidewall damage. My tread was plenty fine on my other tires to just replace one.
    I guess the question is, is there a standard tire tread level that the remaining tires should be at to warrant 1 tire replacement. I don't know what that would be.
    Jul 05 2015
    Lower Hudson Valley
    You can have the new tire shaved to match the remaining tires.
    Aug 06 2015
    MA
    I had a similar situation . Ended up replacing two to have a matching axle. Now I'm not worried about flats due to having an extra used tire in storage
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    How were you able to drive that long with a flat and not know it? Did the TPMS warning not pop up on the dash?
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Aug 16 2012
    MA
    Quote Originally Posted by BigBluu View Post
    The TPMS did go off, but idiot me decided to ignore it because I had just gotten my summer wheels put on, and knew that I forgot to reset the tire pressures into the MMI system, so I thought it was just that. I noticed because the car was drifting to the right, but I thought maybe I needed an alignment or something. It wasn't until I got home and just happened to look at my tire and saw that it was flat.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Tire Rack has several articles discussing replacing damaged tires on AWD vehicles. Worth a read if you're thinking about replacing a single tire and the others are worn.
    http://www.tirerack.com/tires/tirete...&affiliate=TY2
    http://blog.tirerack.com/blog/yokoha...drive-vehicles
    http://blog.tirerack.com/blog/todds-...an-awd-vehicle
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    What's more expensive - an entire set of tires, or an entire driveline?
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Established Member Two Rings kcobourn's Avatar
    Jan 04 2013
    2008 Acura MDX
    United States
    Just had the same exact situation. Call Michelin to explain the situation they ought to goodwill some $$. They credited me $137/ tire (A/S3s) that were about a year old and had 6/32nds left.
    B8 P+ Ti 6MT, APR Stage 2, Alpha Cooling, EuroCode TRUfit, AWE Touring, H&R OE / R Sway, Bilstein B8s, CR-15, JHM SS, Q5 Brembos, ECS two-piece rotors / SS lines, 034 Trans / ECS diff mounts, ECS 8mm(f)/10mm(r)
