Results 1 to 4 of 4
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    Stage 2/3 With O2 delete going for inspection
    Going for inspection soon, Ive read in another thread that if you have 2nd o2 delete the car will fail? I have an o2 spacer and can flash back to stock if I have to but when you scan the car with Carista and check to see if all sensors/moniters are "ready" I get green ready across all sections. Does Anyone have a definitive answer or experience of pass or fail with O2 delete? Just need to know as my inspection is up by the end of this month. Thanks all
    Sent from my SM-G925P using Tapatalk
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by Fastbke170 View Post
    All of your emissions system sensors need to read a ready-state to be determined as operational. That's part one, and pretty much required in every test regardless of state.
    Now whether or not you pass the visual inspection with an aftermarket cat and/or 02 spacer depends on the technician, how thorough he is, and how strict the local state guidelines are.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Apr 26 2014
    San Diego, CA
    I'm curious how your secondary 02 is showing as enabled on stage 2... but I have zero experience or knowledge about that tune you have there.
    May 01 2015
    Northport
    The Tune is Top gear tuning uk. It's an alientech slave tuning box. I have 3 files currently. Stock_stage 2 file and stage 3. 3 is just upgraded from when I recently installed an EC FMIC. I felt the difference in timing and pulls nice. I used to work at a Mazda dealer and will probably have the inspection done there so no issue with hfc. Thanks for your input. 😊
