Hello all,
I'm currently doing a complete swap from A4 2.8 to S4.
Interior is done, suspension is done, full braking system is done.
I have the APB engine bone stock with K03's. have a M box modded at 14psi as well as the OEM S4 fuel pump. I have a good friend selling Frankenturbos with 3.000km on it as he went even bigger and I'm interested.
I am told a Bosch 044 as well as bigger injectors will be necessary if I go with Frankenturbos.
My question is, will an FX400 clutch go on my 5 manual speed transmission as I'm planning to keep it. Also, will this transmission be able to hold 360hp? Can I use my stock LUK flywheel from my 2.8? (It's brand new, has about 1.500km)
What other clutch options are recommended, given I don't do launches at all, I drive the car quite mildly and put around 150km on it a month?
Any input would be apreciated. Thanks!
